Oct 14, 2009, 08:33 AM
Personal Sales Rating: ( 3)
2005 Mitsubishi Lancer Evolution
Drives: '05 AS Evo VIII SSL, '92 Eclipse GSX (Is No More)
Viper Alarm Wiring
When I bought my car, it had a Viper security system in it. I'm not sure what the exact model is or how to find it. But I believe it is causing a problem with my cooling fans and I need a wiring diagram to be able to figure out if everything is hooked up correctly. The fan is on all the time and the speed varies constantly. I can't come up with any other explanation as to why this would happen, hopefully I'm not the only one with this problem.
__________________
XboxLIVE: Evogamer05
Cams, Apexi 3" turboback exhaust with cat, turbosmart BOV, Vibrant filter, Greddy Profec EBC, Tein EDFC, 30R, GT-Spec manifold, Drag DR-31 Wheels (Black w/red lip), Falken Ziex tires
LaScuola Motorsports
Offline
Oct 14, 2009, 02:30 PM
Personal Sales Rating: ( 0)
Drives: 2006 Evolution 9 Special Edition
Here is the shop manual...in the wiring folder-wiring pdf will have all you will need................. http://thefrost.net/randomfiles/rand...005%20Evo9.zip
Offline
Oct 14, 2009, 02:53 PM
Thanks 09Ralli, I'll give that a shot. I'm hoping it's just as simple as finding the wires and hopefully one is hooked up to the wrong one or something. All the wiring I've found in this car so far has been done very poorly with not even twisting the wires and then just taping them together.
__________________
Offline
Oct 14, 2009, 03:03 PM
ya ive been there before, but who knows they might have just tapped into the wrong wire, and you may find it quickly....well thats usually the plan anyways lol
Offline
Oct 14, 2009, 06:51 PM
Personal Sales Rating: ( 25)
Drives: IX
I really doubt the alarm causing this... maybe there wired to be on all the time or check the fan control module....
Online
Oct 14, 2009, 11:07 PM
I wouldn't mind them being on all the time, but would something wired like that cause the variance in the speed of the fan also?
__________________
Offline
Oct 23, 2009, 01:56 AM
Drives: EVO 9 SE
dought full its the alarm. probably a bad relay. but check out THE12VOLT.COM for the wiring diagram on your car
__________________
Evo 9 SE
"if speed kills your lookin at a deadman"
Offline
Nov 20, 2009, 09:34 AM
Fixed this problem a couple weeks ago. It turned out to be a bad fan control module.
__________________
Offline
Tags
2005, 5000, 5900, alarm, car, diagram, evo, ix, lancer, mitsubishi, security, system, viper, wire, wiring  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
