Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 5, 2009, 08:04 PM   #1
Personal Sales Rating: (0)
Drives: evo eight
Wierd whining noise when accelerating
Everytime i turn on the A/C, i hear this whining noise coming from the stereo. Its not coming from the motor cuz when i turn off the stereo, the noise is gone. Does anyone knows what cause this? I do have an amp and sub.
Offline
Old Aug 5, 2009, 08:10 PM   #2
Personal Sales Rating: (2)
newimportowner's Avatar
Drives: 06 TB IX MR SE
its the turbo, turn down your radio and you will hear it more often. Just kidding. I get that too with the AC on and on an AM station.
Offline
Old Aug 5, 2009, 08:20 PM   #3
Drives: 2005 Evo MR
had this issue on another car and I was told its the amperage being pulled from the speakers/amp. Not sure if it was true or not, but it made sense at the time
Offline
Old Aug 5, 2009, 10:52 PM   #4
Drives: evo eight
sometime i cant stand it, so i blast my music up to cover up the whining noise. could it be the battery?
Offline
Old Aug 5, 2009, 11:29 PM   #5
Personal Sales Rating: (24)
My Garage
SICK9's Avatar
Drives: 2006 EVO IX MR [GG], 1999 JEEP Wrangler SAHARA, 2008 Ford Escape Ltd.
You're getting feedback from the amp.
Sometimes you can change to better shielded RCA cables and it will stop that sound.
Or you could try a noise filter inline with the cables.
If it doesn't you might have to move your amp and headunit ground to better spots or add another ground wire somewhere.
I had it on my old car with 3000+ watts and it was a pita to get rid of..
__________________
06 EVO IX MR [GG]
FP RED Turbo [P+C] / GSC S1 Cams / SNOW Alky Inj. / Buschur EM+IM+65mm TB / BC Racing "ER" Coilovers /AMS FMIC / Sparktech C.O.P. / ACT HD + SL FW /
+ Cusco/APR/ARC/DAMD/Rexpeed/Nisei/ XS-Eng./Blox/NRG/Hawk/ViS. etc. etc.
TUNED BY KREIONIC
SCR-SCCA (SM 69)
PICS
Offline
Old Aug 6, 2009, 12:34 AM   #6
Drives: evo eight
i'll give that a try. see if that would work.
Offline
Old Aug 6, 2009, 02:15 AM   #7
Hoaxanie's Avatar
Drives: 05 Lancer ES, 03 Evo VIII
Send a message via AIM to Hoaxanie
its because of the amp...
Offline
Old Aug 6, 2009, 06:12 AM   #8
FJF
Personal Sales Rating: (12)
FJF's Avatar
Drives: IX SE
Quote:
You probably meant to say alternator whine. Feedback results when a sound is fed into a mic, amplified, then re-fed into the same mic.
Good advice. I'd check the grounds as a first step. Not knowing more about the system and the install, it's hard to point to anything specific.
Offline
Old Aug 8, 2009, 10:02 PM   #9
eastxcelerate's Avatar
Drives: 2005 EVO8
Does anybody has the diagram of the amp. I'm having the same problem and planning on rewiring my power feed but needed the diagram on the connector. I separated all the speaker aside but theres still like 6 more wire left. Anybody?
Offline
Old Aug 8, 2009, 10:10 PM   #10
Drives: 03 EVO VIII
Do you have your power and signal wires run together? If so, try running the power and remote switch wires through one side of the car, and signal wires through the other side. I always do this when I do an install, never had that problem.
Offline
Old Aug 9, 2009, 08:03 PM   #11
EvolutionBOOM's Avatar
Drives: evo 9
need better n bigger rca cables
Offline
Old Aug 11, 2009, 09:43 PM   #12
Personal Sales Rating: (1)
bmxer4it's Avatar
Drives: 05 Evo VIII / 90 240sx
Check to see if you are running your wires any where near your fuel pump. If so, there is your problem. dont know why, cuz im not a science guru, but when your wires run near a fuel pump, it gets that whine. Let me know if it works out for ya.
Offline
Old Aug 13, 2009, 05:42 PM   #13
Drives: evo eight
Quote:
what did you do to fix it? did you just move the wire or relocated?
Offline
Old Aug 14, 2009, 01:58 AM   #14
bmxer4it's Avatar
run your wires so they arent near it. first, to make sure its it, wile car is on, listen for the whine. then grab your wires and move them closer and away from it. if you hear the noise change, thats it. hope it helps
Offline
Old Aug 14, 2009, 02:00 AM   #15
bmxer4it's Avatar
Also make sure you have more than enough ground.
Offline
Tags
ac, accelerate, accelerating, accellerating, car, escape, ford, noise, radio, sound, stereo, subs, whine, whines, whining, winding
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
