Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 24, 2009, 12:25 PM   #16
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
Quote:
Originally Posted by cij911 View Post
Ughhhh....I owe you a .. .I assumed the cables that came with the ohm meter were calibrated with the device....Apparently not -- touching the two together yields 0.6 ohms, so I guess my ground location is pretty good 0.2 - 0.4 ohms....
Thanks guys....
It depends on how much current your amp will draw. If you're amp draws 10 amps, it will drop voltage 2 volts with .2 ohms. (V=R*I). So at the moment the amp is pulling 10A the voltage will drop down to 12, assuming 14 to begin with.
I would try to shoot for something better. Maybe even put some dielectric grease between your body and ground washer.
Offline
Old Jun 24, 2009, 09:06 PM   #17
Personal Sales Rating: (2)
LancerEVA06's Avatar
Drives: 06 EVAlution IX; 93 EVO I; 06 ES (DD)
Send a message via AIM to LancerEVA06 Send a message via Yahoo to LancerEVA06
If he's going to running a high quality amp, the voltage drop wont matter. higher end amps are rated at 12.2V rather than 14.4V or 13.8V. As far as dielectric grease... all that does is protects from corrosion... it will add some resistance. Dont know how many light bulb sockets I've had to change in the last 5 years because people put bulb grease (dielectric grease) in them.
__________________
XBL Gamertag: LancerEVA06
Quote:
Originally Posted by LancerEVA06
Me: looks like a shopping cart with that wing.
Him: o jeez
Me: We have Shopping Carts for balls
Me: HAHAHAHAHAHAHAa;sdf
Me: I mean cars
Him: u smoke something there dude? lmao
Offline
Old Jun 24, 2009, 09:23 PM   #18
biggie5252's Avatar
Drives: 06 IX MR
Quote:
True, but my example was if his amp only pulled 10A of current. I would almost guarantee it will be pulling at upwards of 30amps, especially with 5 channels.
Didn't know that about dielectric grease.
Offline
Tags
amp, audio, back, battery, car, good, ground, grounding, place, resistance, running, spot, spots, trunk, wheres, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
