You're not going to damage your head unit with either set of speakers. The rms power rating is what the speakers will handle, not what they're going to try to draw from the headunit. As long as they're 4 ohms (they are) then the headunit won't know the difference. It doesn't matter if its coaxials, components, or thirty pairs of speakers wired together. If it comes to 4 ohms your headunit will only put out up to its rated power (its rated at 4 ohms).
