Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 11, 2009, 01:10 PM   #1
Personal Sales Rating: (9)
QwikEVO's Avatar
Drives: 2003 TB Evo 8
Send a message via AIM to QwikEVO Send a message via Yahoo to QwikEVO
Subwoofer popping
Whenever I turn my head unit down to volume setting 0, change from CD/Radio/Aux, or when I turn the car off the sub pops. When I turn the stereo all the way down to 0, it pops and you can hear a slight hum if you're right near the sub. I probably wouldn't hear it if the car was running, but I could hear the hum while I had my head in the trunk.
Any suggestions?
I sanded down the grounding point and recut another terminal end to the grounding point. I did a resistance check on the ground wire, had continuity and from the ground wire to the mount point was good as well.
Just FYI --- I took the sub box/amp out of the car to go to the track yesterday. Never had this problem before. It worked fine until I reinstalled it last night.
Offline
Old May 12, 2009, 12:58 AM   #2
Personal Sales Rating: (1)
MRCole's Avatar
Drives: 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Send a message via AIM to MRCole
Factory head unit? Or aftermarket? Need a few more details please
EDIT: after reading that again, i presume it's an after market. What kind? What kind of amp/subs, what kind of wiring and RCA's? My preliminary guess is the shielding on the RCA out puts are shot. Or, if you are using a line-level you are getting noise from that.
Offline
Old May 12, 2009, 03:51 PM   #3
QwikEVO's Avatar
Pioneer deck.
MTX sub.
Kenwood amp.
Rockford RCA's.
no line level.
This setup worked flawlessly until I took it out of the car to go to the track Sunday and reinstalled it the same night.
Offline
Old May 12, 2009, 03:54 PM   #4
Personal Sales Rating: (4)
jasonrp15's Avatar
Drives: 2003 Blue By U Evolution 8
Bad Ground maybe?
__________________
Complete Suede Interior. HTA T4Z (GT37R) Fully Built 2.0 Buschur Motor
http://i165.photobucket.com/albums/u...onrp15/car.jpg
AwdMotorsports
http://www.awdmotorsports.com
(954)753-6006
Offline
Old May 12, 2009, 04:06 PM   #5
Personal Sales Rating: (7)
egydude15's Avatar
Drives: GG Ix MR
the hum u hear means the headunit is sending a constant signal to the sub even thou there is no music being played or the sub thinks there is something going on when it's not suppose to be. check your remote wires first make sure everythign is nice and tight, if not then look at the connectors on the back of the sub its self, if it was the ground, the sub would just turn off and not make any sounds. try to reset your headunit sound settings (bass, treble etc) if the setup worked before there is no reason it should not work now unless you dropped it or something like that.
Offline
Old May 12, 2009, 04:11 PM   #6
QwikEVO's Avatar
Quote:
Originally Posted by jasonrp15 View Post
Bad Ground maybe?
Quote:
Offline
Old May 12, 2009, 04:12 PM   #7
egydude15's Avatar
Drives: GG Ix MR
ground would not make a pop, ground completly turns off the system,
Offline
Old May 12, 2009, 04:16 PM   #8
Silver Sponsor
Kevin@MellonTuning's Avatar
Drives: 2006 Evo IX TB
What model # Pioneer?
__________________
-Kevin
2006 Mitsubishi Evo IX
www.MellonTuning.com
- Stock ECU custom tuning Flash ROMs for your EVO done via e-mail or local
Tuning Evo 7, 8, 9, & 10's!
E-mail me at kevin@mellontuning.com if you're interested in getting your Evo tuned!
Offline
Old May 12, 2009, 04:19 PM   #9
QwikEVO's Avatar
Deh-p7700
Offline
Old May 12, 2009, 04:23 PM   #10
Silver Sponsor
I've got the 9800bt and I had that same problem. Try this and see if it helps. http://i22.photobucket.com/albums/b3...PioneerFix.jpg
__________________
-Kevin
Offline
Old May 12, 2009, 04:33 PM   #11
QwikEVO's Avatar
What exactly is that accomplishing?
Offline
Old May 12, 2009, 04:37 PM   #12
Silver Sponsor
You're grounding the RCA's to the frame of the HU to eliminate the ground loop or the buzz that you're hearing. More info here... http://www.caraudio.com/forum/showpo...60&postcount=1
__________________
-Kevin
Offline
Old May 12, 2009, 05:10 PM   #13
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
Yes a bad ground can cause a pop, especially when the volume goes to 0 with a digital volume control. This is a very common problem with Pioneer headunits. There's a little "fuse" inside that blows. It can be caused by unplugging the Rcas with the headunit on.
Did you unplug the Rcas with the headunit still on?
Offline
Old May 12, 2009, 05:13 PM   #14
QwikEVO's Avatar
Initially, no.
But did leave the headunit on while troubleshooting.
Also, my headunit has 3 RCA outputs. How would I ground out the 3rd one that isn't part of the headunit. It's on a cord thats about 3-4" long extending from the back of the headunit.
Offline
Old May 12, 2009, 05:17 PM   #15
biggie5252's Avatar
Drives: 06 IX MR
Wrap a cable around the outside and ground it. Basically your grounding the exposed part of the female rca plug (not the center pin)
Offline
Tags
12, 2006, buzzing, car, evo, headunit, mr, music, pop, poping, popping, pops, radio, soud, subwoofer, subwoofers, turn, turned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
