Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 12, 2009, 05:31 PM   #16
Personal Sales Rating: (0)
Yimke's Avatar
Drives: 98 Talon Esi
Send a message via AIM to Yimke
Ground loop is happening. Here is some reading
http://www.crutchfield.com/S-wOkStfl...ech/kb350.html
or probably bad RCA's. Test them by swapping a new set across the seats to the amp for test purposes. If that solves it there is your problem.
if not try this procedure chart, because that hum is noise in the system. Follow chart till noise from subs goes away.
http://www.crutchfield.com/Learn/lea..._diagnose.html
Offline
Old May 26, 2009, 12:24 AM   #17
Personal Sales Rating: (11)
heel2toe's Avatar
Drives: 05 Evo SSL
Im not sure if this is the same thing but when I installed a full system in my friends car including a headunit speakers and an amp when we turned on the headunit, the speakers would pop. After speaking with crutchfield tech support(they are awesome btw) we were recommended a solution. Apparently the amp was turning on before the headunit and causing a pop. We were instructed to wire in line both a small resistor and capacitor. These were soldiered in line to the switched 12v going to the amp. Now I forget the specifics on the capacitor and resistor however what I can tell you is that it fixed our problem. I suggest getting in contact with someone from crutchfield tech support and see what they can do for you. Good luck and keep us posted.
Offline
Old May 26, 2009, 12:56 AM   #18
2004 Mitsubishi Lancer Evolution
Drives: Evo 8
make sure you amp turn on wire is connected to the blue/white wire from the pioneer harness, and/or turn down the frequency on the amp.
Offline
Old May 26, 2009, 11:59 AM   #19
Personal Sales Rating: (9)
QwikEVO's Avatar
Drives: 2003 TB Evo 8
Send a message via AIM to QwikEVO Send a message via Yahoo to QwikEVO
swapped RCA jacks on the back of the head unit. problem gone.
guess that set on the back I was using is FUBARED.
Offline
Tags
12, 2006, buzzing, car, evo, headunit, mr, music, pop, poping, popping, pops, radio, soud, subwoofer, subwoofers, turn, turned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
