May 24, 2009, 03:40 PM
Personal Sales Rating: ( 6)
Drives: Tarmac Black 05 GSR SSL
wow.. do people still install stereo's w/o using a harness nowdays?
Offline
May 24, 2009, 03:54 PM
Personal Sales Rating: ( 2)
Drives: '03 Lancer EVO VIII
A quick test for my suggestion would be to (with car off) take your multimeter red + lead and touch it to the wire you have hooked to your red wire from the cd player (with the black - lead obviously touched to ground). Now turn your headlights on and see if you get 12+ volts. If not, check the wire that is hooked to your yellow wire and do the same thing. That should let you know if my theory is true.
__________________
I miss my:
03 EVO 8 Apex Silver
Offline
May 24, 2009, 10:46 PM
Personal Sales Rating: ( 28)
Drives: 06 IX MR
Quote:
If this were true, his headunit would only turn on when his parking/head lights were on.
Online
May 25, 2009, 09:13 AM
I guess theres not much I can dispute about that!
I still think he has the illumination wire from the car going to the wrong wire on the cd player, and still think he should verify which wire is actually the illumination wire with a multimeter.
__________________
I miss my:
Offline
May 25, 2009, 09:41 AM
Drives: 06 IX MR
His wiring is correct according to my car.
OP what do you have the green/white wire connected to? Are you using a harness adapter or is the deck hardwired to the car?
Online
Sep 23, 2009, 11:38 AM
Personal Sales Rating: ( 0)
Drives: 2004 Mitsubishi Lancer Evolution VIII 1995 Honda Civic Hatch DX
Thanks I've been really busy and unable to try to fix this.. but I should have some free days next week and I'll try everyone's ideas.. thanks again
Offline
Tags
bigger, blowing, blows, cd, deck, evo, fuse, fuses, ground, illumination, install, player, quick, test, wire, wires  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
