Apr 17, 2009, 08:06 PM
Personal Sales Rating: ( 0)
Drives: evo x mr, bmw 530xi
need help with install
i recently took my evo x to get a remote starter installed and the shop is having a problem getting it to work. it will only work with the ignition in the accessory position.i have the fast key option. does anybody know what the accessory position powers up? or what it does? i need to know this before install is complete. please help!
Offline
Apr 18, 2009, 03:23 PM
Personal Sales Rating: ( 1)
Drives: 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Um, it won't work because it needs a bypass for the car to turn over...if you have that, then they didn't hook it up properly. If it cranks but doesn't turn over, could be not sensing chip...there are ton's of reasons why it's not working. Ask for a refund and take it somewhere else.
Offline
Apr 18, 2009, 03:26 PM
1998 Mitsubishi Eclipse My Garage
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
You're probably going to have to hide an extra key somewhere in the car so that the stock imobilizer/Fast key system thinks your in the car and allows it to crank.
__________________
Skeet
Driven to Thrill
Offline
Apr 18, 2009, 09:34 PM
it is a compustar remote start and a can-sl2 bus interface. they did hide a key in the car. the starter would work fine as long as the ignition was in the accessory position. if it was in the off position the car would not start.
Offline
Apr 18, 2009, 10:39 PM
Does the car crank at all when you remote start it?
Offline
Apr 19, 2009, 05:19 AM
yes, it actually starts when the ignition is in the accessory position. when it is in the full off position it does nothing.
Offline
Apr 19, 2009, 03:20 PM
Double check the antenna ring, double check they wired all the ignitions and accessories.
Offline
Apr 19, 2009, 09:10 PM
what accessories have to be wired? or i guess i should say "how"
Offline
Apr 20, 2009, 02:41 AM
Don't have a wiring diagram on me atm, meter the wires to be certain. Soldier and tape.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
