Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 14, 2009, 09:32 PM   #1
Personal Sales Rating: (15)
Drives: 2005 Evo GSR w/ SSL
SSL sound system breaking up at high volume
Ok so i pulled the car apart today looking for a bad ground , Cuz Once you turn volume past 20-22 , It cuts out , Sounds like a bad ground. Cant find anything loose. Im kinda stumped. So im gussing the amp is going or possibly the headunit's signal is clipping.
Any suggestions on how to narrow down what peice is going. Or any other suggestions on how to fix it
__________________
Evo 9 Turbo ,JIC manifold ,QTP 3inch DP w/ Cutout ,
Comp 280 cams ,Fidanza cam gears , ETS Lower IC pipe , Perrin FMIC , Halman MBC ,AEM Intake ,Megan o2 housing ,AMS 880cc injectors ,255 Pump , ACT flywheel/clutch ,Agency Power Short Shifter ,Inovative Wideband.
Offline
Old Apr 16, 2009, 06:35 PM   #2
Bump?
__________________
Offline
Old Apr 18, 2009, 03:25 PM   #3
Personal Sales Rating: (1)
MRCole's Avatar
Drives: 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Send a message via AIM to MRCole
Set all EQ's or treble and bass to 0, then try again. If it continues, ohm speakers out. Next, if they all read about the same, check for lose power, bad ground, partial blown fuse. If that's not it, bad amp.
Offline
Old Apr 18, 2009, 09:32 PM   #4
thx , i checked for lose grounds/power etc , ill try the fuse issue and the speakers , Easyest way to check speakers would to be from the amp input correct , or from the back of the radio? Instead of pulling the door panels off
__________________
Offline
Old Apr 18, 2009, 10:38 PM   #5
MRCole's Avatar
From the amp, to the speakers.
Offline
Old Apr 26, 2009, 03:59 PM   #6
Havnt had the chance to check speakers , but when i dail down the bass setting all the way , I can put it up much louder... Cuz its using less power i suppose... Seems like the amps going?
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
