Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 12, 2009, 03:01 PM   #1
Personal Sales Rating: (0)
Xearo's Avatar
Drives: 04 Evo8
Pioneer AVH-P5000DVD
I just bought the Pioneer AVH-P5000DVD and hopefully will have it by next week. I also bought the Garmin nuvi 880 and i will use that for bluetooth rather than the dvd.. Well actually maybe not. I bet the dvd player will lower the volume for you when u get a call. But i think u have to by an accessorie for it. ? Mine will be 6.2". Im concerned about fitment.
Anyone else notice (at least in an 04 gsr) that there is no ground wire coming from the dash harness?! I noticed my head unit still works without a ground wire but my guess is it is grounding through the rcas to the amp wich is a no no.
Anyone have experience with the DVD player im buying (Pioneer AVH-P5000DVD)?
I bought it becasue it has 4v preouts and USB capability. I want to be able to display jpgs, and play mpgs that i get off the internet. Anyone know if thats going to be possible?
__________________
Want to buy the SSL sub enclosure. Or a custom made enclosure for the Evo that fits in those side pockets.
Offline
Old Apr 18, 2009, 03:38 PM   #2
Personal Sales Rating: (1)
MRCole's Avatar
Drives: 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Send a message via AIM to MRCole
I am familiar with the 5500dvd, so can't comment on the USB playback of .avi and .mpg. Ground it to the chassis and you're all set. To comment about there is no ground wire in yours, if the RCA's were grounded, you would get hella noise through them. So no, that's not your ground point. It's your antenna OR the brackets to the side of the radio that is making a ground.
Offline
Old Apr 19, 2009, 04:53 AM   #3
Xearo's Avatar
Drives: 04 Evo8
interesting. Ok so check this out.
Noise crappy noise. But when i run a wire which is connected from the chassis to the ground portion of any of the RCA's, the noise is completely gone. Weird huh? I think i have a floating ground inside my headunit for the RCAs. Which means, where the outside part of the RCA;s connects (ground) there must be some reistance between that point and where it reaches the normal signal ground. Something is ****ed up i think. Grounding the RCAs straight to the chassis is fine but letting them ground through their normal connection cuases noise. Any electrical engineers care to chime in?
Also i only need to ground one channel of the RCAs, nott both. Also grounding from the chassis to the head unit frame doesnt do any good..
Offline
Old Apr 19, 2009, 03:23 PM   #4
MRCole's Avatar
Yeah, there is a problem with internal circuitry of the head unit. In most cases grounding the RCA's will produce noise, in your case it doesn't. Easy fix, ground out one of the RCA's. I've only had to do that maybe 5% of my thousands of installs.
Offline
Old Apr 19, 2009, 03:25 PM   #5
MRCole's Avatar
Forgot to mention, Pioneer is notorious for their RCA's to be poorly grounded.
Offline
Old Apr 20, 2009, 06:54 PM   #6
Xearo's Avatar
Drives: 04 Evo8
i had an old mtx amp that did something similar. I opened it up and the rcas had a cold solder joint from the rca cables being plugged in so many times, the rcas connection to the pc board finally came out of the solder. I took out my soldering iron, and only had to touch the solder to melt it all togerther again. Didnt have to throw it out after that.
Offline
Tags
5500dvd, avh, pioneer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
