Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 6, 2009, 04:55 PM   #1
Personal Sales Rating: (0)
Xearo's Avatar
Drives: 04 Evo8
Lightbulb Install questions...
Heres what I need to know and didn't see infor on it...
1) The 6.75" speakers in the door: How do i run those to an amp? In my integra, there were 2 extra wires in the connector which were unused! ideal for runnning wires to the door speakers. Also, how do u remove the door panel? (Or similar to the integra -do u just pull off the grill from the speaker?)
2) The A piller tweats: How do u get to those speakers to rmove them? (and to run wire to them.)
3) The rear 6.75s: How do u get those out?
4) The din cover: Do u just pry on it to get it out?
Offline
Old Apr 6, 2009, 07:10 PM   #2
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
You can just tap into the existing wires. To get the door off (no you can't just pull the grille), there's a screw in the grab handle under the little cover. There's a screw under the little cover behind the opener/lock thing. There's a screw under the trim behind the mirror. 2 screws at either end of the panel behind the little round trim things. After you get those screws out, pull starting at the bottom until all the clips pop, then lift up and out.
Apillars - pull the weatherstripping down away from the trim. Pull the trim towards the inside of the car. More than likely the clips will pull off the trim so you'll have to pull them out of the car and put them back onto the trim. 2 screws to get the tweeters off the car.
In the trunk there's bolts or nuts (10mm I believe) Undo those, then pull the grills up from inside the car.
Radio cover - remove the a/c knobs. There's a screw behind each of the large ones. Pull the trim out after screw removal. If it's the bottom cubby, there's two screw at the top, remove those and pull out.
Offline
Old Apr 6, 2009, 10:12 PM   #3
Xearo's Avatar
Drives: 04 Evo8
good stuff thanks alot! i will get started tomoorrrow!
Offline
Old Apr 8, 2009, 02:23 PM   #4
Cyclonick182's Avatar
Drives: LY 03 Evo VIII, 98 Red Eclipse GS
Its its not already stickied somewhere, this needs to be. I spent an hour last night just looking at the door panels trying to figure out where all the screws are.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
