Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 5, 2009, 12:01 PM   #1
Personal Sales Rating: (0)
D1no's Avatar
Drives: 2004 Ralliart
Upgrading Battery Terminals
I am looking to upgrade my battery terminals. The "+" needs to accept one 0 guage, two 4 gauge and the stock wiring block thing. The "-" needs to accept one 0 gauge, two 4 gauge.
Right now I have terminal rings at the end of the wires connected to the stock battery terminals mounting bolt. The 0 gauge wire is from the big 3 upgrade. One 4 gauge "+" and looking to add another 4 gauge "+", one for each amp.
The terminal rings seem to be too big and not making a full surface connection to the stock battery terminal.
There are alot of upgrade terminals available. I want to find out how people here in the forum deal with that fuse block comming off of the "+" stock wiring. Does the upgraded terminal need to accept this stock "+" wire terminal block? Which upgrade terminals did you use?
Thanks.
__________________
Alpine 9830 - eD 6500s-JL 300/2 - Arc Audio Flatline 12- Arc Audio 1000.2T
Offline
Old Apr 5, 2009, 12:08 PM   #2
Personal Sales Rating: (21)
edardnaekim's Avatar
Drives: yes
Send a message via AIM to edardnaekim
google tsunami battery terminals. idk if there is anything out there for the fuse block though...
Offline
Old Apr 5, 2009, 12:33 PM   #3
D1no's Avatar
Thanks Bro. I need to find out how the people on here delt with the "+" wires and the stock fuse block. Then I can choose the right terminal with the correct size, type and number of outputs.
__________________
Offline
Old Jun 16, 2009, 12:08 PM   #4
Personal Sales Rating: (4)
itzwolf's Avatar
Drives: Yellow Evo VIII
Quote:
Did you ever find a solution for the positive side terminal and factory positive wiring? I am looking for a clean option as I am rewiring for an Iraggi 180amp alternator using 1/0g wire...
Offline
Old Jun 18, 2009, 01:23 PM   #5
D1no's Avatar
I ended up removing the stock batt. terminal and soldering a 4 ga. wire with spade terminal, to the positive cable. I left the diode piece intact. I cut up the red positive terminal cover, into a box shape. Covered the two soldered connections with this box and just wrapped it all up with good quality electrical tape. I then tucked it and zip tied it under the battery tray. 4 ga. from there to Stinger cable terminals. I did not like doing it like this, but it worked out great.
Four power wires, three 4 ga. and one 0ga. to the terminal just doesnt look good to me.
I think a distro. block somewhere, with just a single 0ga. to the bat. terminals would look cleaner.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
