Quote:
Originally Posted by turbolagdsm
Im talking about the facrtory security. The car will not run without the key so hows it possible that with a turbo timer the car stays running when you pull out the key?
This is my understanding of how a turbo timer works. It works very much so like a relay. It taps into your ignition harness and in your ignition harness there's a few wires there. The main wires the turbo timer uses are the accessory, 12v, and ignition wire. When the power is cut off to the accessory wire (when you turn the car off), the relay connects the 12v wire to the ignition wire (to keep the car running) for as long as the turbo timer is set.
As for added security, Most turbo timers have a parking brake wire and speed sensor wire that should be hooked up so in any case which your car is left running and/or unattended, should the parking brake be disengaged or the car starts rolling, the turbo timer will shut off and the car will shut off along with it.
