Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 29, 2008, 07:04 AM   #1
Personal Sales Rating: (5)
raasfaas's Avatar
Drives: 06' IX MR GG
SRS light comes on after alarm install...
I need some help here, I recently got a hornet alarm system put on my car, alarm works fine and everything but since then the SRS light has come on. I tried disconnecting the battery for a few minutes but it didnt come off. I got the installer to over look his work to see if he left off something but all looks well.
Is there something that needs to be reset or done?
__________________
AEM cone filter | Forge DV/BPV | DC dp w/ cat delete | HKS Hi-Power Exhaust | Ebay O2 housing | Walbro 255lph pump | AEM tru-boost EBC | ETS LICP | ETS FMIC | AEM Meth 75/25 | ARP Headstuds | ACT HDSS | Tephrav5.10 w/JT Map Switch | everything else stock
Self Tuned
ET11.71@117.8mph
MGW & Lueboyz Racing to di werl!!!
Offline
Old Oct 29, 2008, 07:16 AM   #2
Personal Sales Rating: (13)
rcheung's Avatar
Drives: 2003 Evo 8
SRS light will not come off without an SRS scanner. Nothing you can do will make it dissapear otherwise. If you know a bodyshop they may have one. Otherwise you may need to go to the dealership. An alarm should not have caused the SRS to go off unless one of the SRS plugs were removed and put back while the alarm was installed or an in incorrect wire may have been cut.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
Old Oct 29, 2008, 09:33 AM   #3
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
I would go to another shop and have them check it out. As said above there's no reason SRS should have come on for an alarm install.
Offline
Old Oct 29, 2008, 02:38 PM   #4
raasfaas's Avatar
yea i know, i'm going to try and find someone with that SRS scanner and see if that works...
__________________
Self Tuned
ET11.71@117.8mph
Offline
Old Oct 29, 2008, 06:26 PM   #5
Personal Sales Rating: (11)
Aman's Avatar
Drives: 03 Evo 8
just a word of advice , make sure none of ur alarm power source of picked up from SRS or any wire were taped on srs . check ur air bag connections. DO you have after market steering wheel.
Offline
Old Oct 29, 2008, 08:44 PM   #6
raasfaas's Avatar
Hmmm, i'll have to let them check that...no i have the stock steering wheel.
__________________
Self Tuned
ET11.71@117.8mph
Offline
Old Oct 29, 2008, 09:29 PM   #7
biggie5252's Avatar
Drives: 06 IX MR
Hopefully, they just unplugged something by mistake while they were installing the alarm, plugged it back in, and it just needs to be reset.
Offline
Old Oct 30, 2008, 06:39 PM   #8
Aman's Avatar
Drives: 03 Evo 8
can u pull the code out ???
Offline
Old Oct 30, 2008, 07:46 PM   #9
raasfaas's Avatar
thanks for the help guys, turns out the installer did unplug one of the srs plugs which brought up the light...I got a shop to do a diagnostics test and just reset the codes...all is well now.
__________________
Self Tuned
ET11.71@117.8mph
Offline
Old Oct 30, 2008, 07:54 PM   #10
biggie5252's Avatar
Drives: 06 IX MR
Good. Nothing like an airbag going off in your face.
Offline
Old Oct 31, 2008, 12:13 PM   #11
Personal Sales Rating: (16)
randomevo's Avatar
Drives: 03 Tarmac Black
how much did they charge you to reset the code?
If only this could be done through a tactrix cable and some pretty fancy software.
Offline
Old Nov 5, 2008, 08:45 AM   #12
raasfaas's Avatar
I was fretting the airbag was going to fly and slap me in the face everytime I drove it...
Fortunately I knew the people at the shop I went to so they didn't charge me
__________________
Self Tuned
ET11.71@117.8mph
Offline
Old Mar 14, 2009, 05:12 PM   #13
Personal Sales Rating: (0)
EvolManiac's Avatar
Drives: Evo VI & IX
will the airbags still work even if the lights are on?
Offline
Old Mar 14, 2009, 06:46 PM   #14
Fevaick's Avatar
Drives: Fevaick
diamond jewelry
We offers an extensive inventory of certified loose diamonds anod fine jewelry at direct from the manufacturer, wholesale prices, without sacrificing quality or service. In addition, many of our products are priced at 25% - 50% less than the leading online retailers. mj diamond jewelry
Offline
Tags
06, alarm, cable, evo, evolution, forum, hornet, lancer, light, lights, reset, srs, system, tactrix, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
