Oct 22, 2008, 09:20 AM
Personal Sales Rating: ( 1)
Drives: 2005 VIII
Factory Sub
does anyone have a clue if or how to add a amp onto the factory sub? i have an alpine deck with the preouts just trying to figure out how to hook it up
Offline
Oct 22, 2008, 11:04 AM
Personal Sales Rating: ( 3)
Drives: 06 TB Evo IX SE
I wouldn't waste money on an amp to power just that one sub. It's only 8" (if I remember correctly) and it's probably pushing enough power as is.
__________________
2006 Evo IX SE
-AMS TBE w/ TP-
-WORKS Drop-IN-
-Walbro 255-
Kuniiizzzeee Dial-IN!
Need help with your Evo?
Visit EvoGarage.net today!
XBOX LIVE: EvOwNeD
Offline
Oct 22, 2008, 11:09 AM
Personal Sales Rating: ( 7)
Drives: Graphite Grey IX SE (88590015), '04 FZ1, Former: 35R Powered Eclipse GST, 6/4 TSi AWD, Bandit 600s
People have done it and basically decided 'not worth it'
__________________
Corn Fed 365hp/360tq - AMS FMIC, AMS LICP+UICP, AMS Front lower motor mount, Megan O2, Megan DP, Perrin HFC, Fujitsubo RM01A Cat-back, Walbro 255, RC 1200cc Injectors, GSC S1 Cams, Ghetto 3" intake +AMSoil EA Filter
- Tephra V6, JDM MAP, Direct boost ctl w/ AEM solenoid, AMS Tuned
- Pioneer DEH-P9790BT, 40GB iPod, 10W6V2, Alpine PDX-1.1000, Passport 8500 x50 Hardwired, AEM Tru-Boost (Guage only), Auto-dimming mirror, 35% Tint
Offline
Oct 22, 2008, 11:10 AM
Personal Sales Rating: ( 5)
Drives: 05 EVO VIII
Their is already an amp under the seat, if you have an aftermarket head unit, you need to get the correct wire harness that hooks up the the RCA's, its made by Mitah, just search that, its what you need.
__________________
Hallman MBC - Defi boost gauge - AEM UEGO - Perrin TBE, SRI, FMIC, BOV, boost tube, oil catch can, antenna, end links - HPF LICP - Sun Hyper Force - Walbro 255 - Blitz radiator cap - Agency Power 27mm rear sway bar, front mount - Cusco V1&V2 tie bars, front/rear strut bars, trunk bar - Dynoflash custom tune
Offline
Oct 24, 2008, 07:54 PM
Drives: Black 03 Evo 8
It wouldn't sound right if you used a aftermarket amp for you factory subs. It will suck, just go with the full upgrade
Offline
Oct 25, 2008, 05:10 AM
Personal Sales Rating: ( 0)
Drives: Sometimes
Quote:
+1
If you want a cheaper alternative than a full system there is always base tubes but imo they aren't very good either but would still probly be better than trying to put an amp on the stock sub which probly wouldn't be able to handle it anyway. you can get a couple aftermarket 8" subs with a small 250 watt amp pretty cheap though I'd go that route if its a money issue and you want an upgrade. If it isn't a money issue then by all means there are MANY great ways to fill up your trunk.
__________________
Like spending money? how about spending $5,000,000 a day? do that for 2000 years and you will catch up to what Obama has done in 4 months!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
