Stock system plus advise
I am planning my install for my CarPC and an audio setup to go with it. The CarPC I have all sorted out, but need a some information about the stock system and would like a little advise about other components. I will be removing the head unit completely and using strictly the PC for audio/navi. The speakers will be staying stock (for now). I also am going to be installing a 12" sub at the same time. So here are my questions...
Should I use a 6-channel amp or a 4-channel and a mono for the sub?
What are the stock speakers rated at?
Someone suggested that I use a sound processor to connect via SPDIF instead of the three 3.5mm jacks. Any input/advise on this?
__________________
Works TBE (no cat), FP Green, FP O2 Housing, AEM EMS, RC 1200s, K&N Filter, AMS FMIC, Mini-batt, 255 Fuel Pump, HKS 272s, ARP Head Studs, Works Alum Flywheel, Works Clutch Kit 1, Halman MBC, Works Brake Package 2...plus little stuff.
