Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 13, 2008, 09:01 AM   #1
Personal Sales Rating: (31)
J8dailo's Avatar
Drives: Evil
Send a message via AIM to J8dailo Send a message via Yahoo to J8dailo
1000 rms
..im recent bought 2 rockford p3 at 500rms each at 2 ohms for a total of 1000 rms and a 2 channel amp capable of 1400rms at 2 ohms...i have everything wired up correctly and use a hi lo converter to tap into the rear speakers...the sub just doesn't sound like 1000 rms...with window close...it sounds ok...with the trunk open...the bass is not even worth mentioning..barely feel anything... when i stand outside with music full blast...i barely feel any bass coming from it..all i hear is trunk rattle...its pretty disappointing...im not sure what went wrong.... the only thing i can think of is that i have SSL with stock amp and stock headunit...people told me i need a new headunit to make it sound right... can anyone fill me in...
__________________
STOCK PARTS FOR SALE:
STOCK INTAKE
STOCK TARMAC BLACK HOOD(DAMAGED) $100 PICK UP CHICAGO
STOCK EVO VIII P/S TAILLIGHT PM WITH OFFER
P45R GOLD WITH POLISH LIP 18X.9.5 +30MM WITH CUSTOM HUBCENTRIC 8MM SPACER UP FRONT WRAPPED IN AGGRESSIVE ADVAN NEOVA 265/35/18 - ONLY LOWERED $900 PICK UP!! WILL SHIP FOR REASONBLE PRICE..PM WITH OFFER
P45R TIME ATTACK 18X9.5 +20 FRONT +30 REAR..WITH 255/35/18 TIRES! NO SPACER NEEDED AND CLEARS STOCK FENDER WITH NO RUB! $1150 PICK UP!!
Offline
Old Aug 13, 2008, 12:09 PM   #2
Personal Sales Rating: (1)
EvoVIIIGuy's Avatar
Drives: 2003 Acura NSX
Send a message via AIM to EvoVIIIGuy
The Biggest down fall to this set up is the Highlow converter.
If you have an Ipod or mp3 player, Go to radio shack for 5$ and get a headphone male to L/R Rca and hook it directly to the amplifier. This will give you a much better idea as to what kind of out put to expect from this set up.
If it is significantly more output then you know where your weak points are, hilow converter or the factory output on the deck.
__________________
Every Time I Step On the Gas, A Smile Comes To My Face!
Offline
Old Aug 13, 2008, 02:05 PM   #3
Personal Sales Rating: (5)
dan628's Avatar
Drives: 05 EVO VIII
How are you wiring the subs/amp? If you have 2ohm speakers, then if you wire them in parallel your amp is seeing 1 ohm load. WHen you say you have a 2 channel amp, is that 1400 watts bridged mono or what? If it is bridged 1400 watts at 2 ohms, and you are hooking up 1 ohm load, then something is not right. If you just wired them stereo chances are they are not getting enough power.
__________________
Hallman MBC - Defi boost gauge - AEM UEGO - Perrin TBE, SRI, FMIC, BOV, boost tube, oil catch can, antenna, end links - HPF LICP - Sun Hyper Force - Walbro 255 - Blitz radiator cap - Agency Power 27mm rear sway bar, front mount - Cusco V1&V2 tie bars, front/rear strut bars, trunk bar - Dynoflash custom tune
Offline
Old Aug 13, 2008, 02:16 PM   #4
Silver Sponsor
Personal Sales Rating: (66)
4WS Tuning's Avatar
Drives: Faster Than A Cheetah On Cocaine
Send a message via AIM to 4WS Tuning
Check the wiring like Dan628 said... You need to wire it in a series so youre over the 2ohm.
http://akamaipix.crutchfield.com/ca/...2-ohm_mono.jpg
With this diagram you'll be hearing some boom, just not getting the full 1000rms from the amp. You'll actually be getting half that...
If you can return the subs and get two 2ohm dvc then you'll be able to run them at 2ohm and get the full power from the amp.
Cheers!
__________________
4WStuning.com
Click for Custom E-Flash & Road Tunes!!!
Click For Tactrix Cables, Hallman Boost Controllers, Labonte Methanol Injection Kits!!!!!!!!
No Tactrix, No Problem! CABLE RENTALS!
Call/Text ::: 305-979-TUNE [8863]
AIM & E-Mail!!!!!! ::: [Tamer@4WStuning.com]
Offline
Old Aug 13, 2008, 02:41 PM   #5
EvoVIIIGuy's Avatar
So with a two 2 ohm speakers you have the ability to wire this set up as a 1ohm load or a 4 ohm load. A 4ohm load will net you only 700 watts of out put from the amp split between 2 speakers.
The 1ohm load wire set up will net you 2800 watts, if your amp can take it, but probably not.
Time to get another amp, or different subs to extract the best from your system.
__________________
Offline
Old Aug 13, 2008, 07:28 PM   #6
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
Wire the woofers you have in series = positive of 1st woofer to negative of 2nd woofer. Connect negative of 1st woofer to negative of amp and positive of 2nd woofer to positive of amp. That will get you a 4 ohm speaker load, which when you bridge your amp it will get you the 2 ohm load that you need. How do you have the woofers facing in your trunk? What kinda amp is it (brand/model)?
Offline
Old Aug 13, 2008, 09:06 PM   #7
J8dailo's Avatar
Drives: Evil
the subs are dvc 4 ohms and i wired them up in parellel for 2 ohm load to amp... the amplifier is from Diesel audio... i am not sure if its rated 1400rms bridged mono..all it saids is 700 Watts x 2 Channels @ 2 Ohms..i already lost the manual to it and it doesn't give much more information about it on its website.... i have the subs wired at 2ohm to each channel on the amp
__________________
STOCK INTAKE
Offline
Old Aug 13, 2008, 09:15 PM   #8
J8dailo's Avatar
Drives: Evil
i also have a box built for inverted mount subs... i had the subs mounted the traditional way at first and it sounded ok... the i reverse mount the subs and it sounds somewhat better due to extra area in the box...
__________________
STOCK INTAKE
Offline
Old Aug 14, 2008, 02:57 PM   #9
biggie5252's Avatar
Drives: 06 IX MR
I'm going to take a guess and say you're actually getting 350w rms x2 @ 2 ohms. You have the woofers wired correctly. That way is actually better than bridging the amp. I doubt the woofers sound better due to the extra space, just because it's such a small difference, but rather the fact that you effectively reversed the phase of them, assuming you wired them the same as before. If you don't like them inverted, you can put them back the way they were, and reverse the positive and negative connections and I'll bet they'll sound the way they do now.
Offline
Old Aug 14, 2008, 02:59 PM   #10
J8dailo's Avatar
Drives: Evil
i tried reversing the phase of the sub between the 2 type of mounting and it sounded no different... what i notice today was that when i turn the volume pass 23 on the stock headunit...the sub bass actually diminishes..doesn't get any louder... i think it could be in the hi lo converter itself...i remember most hi lo converter are only good for certain wattage... maybe its time for a new headunit
__________________
STOCK INTAKE
Offline
Old Aug 14, 2008, 03:28 PM   #11
EvoVIIIGuy's Avatar
Im telling ya.. Try that Ipod hook up first!!
Becuase the car is not infront of me there is little more to say, the suggestions here are correct to see if things are wired right.
__________________
Offline
Old Aug 14, 2008, 04:17 PM   #12
biggie5252's Avatar
Drives: 06 IX MR
Does the amp have a speaker level input? How big is your enclosure? While using an LOC on a factory HU is never ideal, it's very possible. There's no reason you shouldn't be able to get the kinda bass you want with this. Is there a level control/gain on the LOC? What about gains on your amplifier? Do your woofers physically move like they're actually getting the power they should be getting? Are your woofers facing the back of the car, or the front? Sorry for all the questions, but they may help.
Offline
Old Aug 14, 2008, 05:47 PM   #13
J8dailo's Avatar
Drives: Evil
i actually tried that with another setup on my other car...its not very ideal because if i hook ipod via earphone jack straight to amp..the ipod does not output enough voltage to the amp to show capablity of the subs... i looked into this setup before..the only way for it to work is to incorporate some kind of voltage amplifier between the ipod and the amp... im not sure how u have it but this does not work as far as i know...
i have the sub invert mounted as far as right now..the box is ported and its facing toward the rear of the car...i i sat in the new eclipse with the 600w rockford system..probably the same one as in evo x...my sub sounds somewhere close to that setup...its not very satisfying as far as my taste goes..
__________________
STOCK INTAKE
Offline
Old Aug 15, 2008, 05:32 PM   #14
J8dailo's Avatar
Drives: Evil
i think my amp is drawing too much current from my stock alternator...this is probably why my interior light still dims even with cap and sub performance diminishes at higher volume... man...i really regret upgrading to such a big system now...should've stick with one p3 and a smaller amp and box.... i probably need to upgrade my alternator for my setup...
__________________
STOCK INTAKE
Offline
Old Aug 15, 2008, 06:09 PM   #15
biggie5252's Avatar
Drives: 06 IX MR
What battery are you using? How big are the fuses on the amp? Where did you ground the amplifier and how big is your power/ground wiring? Granted, the evo alternator is small, but it's not much smaller, if any, than most cars. If your dropping voltage so much that you hear a difference, I'd look at your connections, or into replacing your battery first. I've had well over 1000wrms running on a similar sized alternator and a Optima yellow top and it did it just fine. The headlights hardly dimmed.
Offline
Tags
1000, 1000rms, 2ohm, amp, back, car, channel, cheap, connect, facing, mount, reverse, rms, subwoofer, subwoofers, woofers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
