Need help.Sub and amp wiring Alpine type r
So I came across a brand new alpine type r subwoofer (12" ,dvc, 4 ohm,500 watts rms).I have a Kenwood Kac-929 laying around. Here are the specs for the amp:
stereo or bridged mono output
Tri-way capable (Tri-Way Crossover required)
460 watts x 1 in bridged mode
230 watts x 2 at 2 ohms
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
50-200 Hz low-pass crossover, 18 dB/octave
selectable 0/+6/+12 dB bass boost at 90 Hz
speaker-level inputs
4-way protection circuitry
cooling fan
signal-to-noise ratio 100 dB
I have the sub wired in parellel and bridged at the amp for now.Would the way I have it wired be the safest way to wire?
