Infinity/Alpine setup
Get ready for a lot of dumb questions:
I have a Infinity 1211a amp and am looking to purchase (2) Alpine Type-R 12's.
The specs on each are as follows:
Infinity 1211a -
854W RMS x 1 @ 4 ohms
1300W RMS x 1 @ 2 ohms
Alpine Type-R 12's -
500W RMS
I want to run both of the 12's at their max, so I will need to run the amp at 2 ohms.
Now for the questions.
1.) Should I buy the 2 ohm or 4 ohm subs?
2.) Based on the #ohm sub I buy, how should I wire them (if you could please be specific, parallel and series dont help me much, I need positive to negative talk!)
3.) How do I make my amp put out 2 ohms? Is this done in the wiring of the subs?
What I would like to do is buy the 4 ohms subs (if they are correct for my application and are more readily available) and have someone tell me how to wire them together as well as to my amp so that the amp is pushing them all out.
Thanks a lot stereo gurus!
