Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 2, 2008, 10:44 AM   #1
Personal Sales Rating: (22)
NocturnalEVO's Avatar
Drives: 2006 Lancer Evolution IX MR
Send a message via AIM to NocturnalEVO
Amp on Sub Enclosure Problem?
Hey all,
I was wondering if anybody else had a problem similar to mine..
I have a JL Audio 500/1 Amp and a JL Audio 10W6v2 subwoofer.
The amp is mounted to the back of the box. (because there was no room to put the amp anywhere else, as my high's amp is mounted on the back of the seat). Now it sounds fine, but what it's been doing is basically that the amp keeps cutting out. I'll be listening to my music and all of a sudden the bass will cut out, and every now and then it'll come in for a second and then cut out again.
The gains are also set pretty low.
The reason I think the amp on box is the problem, is because my friend had the same exact setup as me, and his kept cutting out as well. He figured it was from the bass vibrating the amp. He moved the amp off the box onto the floor and he never had that problem again.
In my case, i'm thinking it could be the same thing, but it doesn't seem like it completely, because the amp doesn't cut out when the bass drops or anything, even if there's very minimal bass it'll cut out.
Its very frustrating
__________________
Najeeb
'06 Evolution IX MR
'06 R6 Anniversary Edition
Offline
Old Feb 2, 2008, 12:46 PM   #2
EvoM Moderator
Personal Sales Rating: (24)
atombomb33's Avatar
Drives: Evo X - GSR
Do you have any pics of the install you could post?
I had the 500/1 pushing a 12W6 and never experienced any problems. But, my amp was not installed on the sub box.
I don't think the way you have it mounted would matter since the screw-down connections on the JL amp make a pretty damn secure connection.
Maybe just try removing the amp from the box and see what happens? If it continues to do it we can try to troubleshoot it for you.
__________________
2008 Evolution X - GSR Apex Silver /// SSS - Aero - Navi
Forum rules & regulations
Offline
Old Feb 2, 2008, 01:45 PM   #3
Personal Sales Rating: (5)
Jameson_IXMR's Avatar
Drives: an evo duh?
Check all of your wiring, that is a bad place for the amp but it is solid state, and shouldnt disrupt from some shaking like that, should be more of a long term effect.
Offline
Old Feb 2, 2008, 08:18 PM   #4
Personal Sales Rating: (9)
LayinLo's Avatar
Drives: Gixxa, 03 TB VIII
Never had this problem from mounting on the box. Check wiring.
Is the amp new?
__________________
Yes . . . that's me on the bike.
Quote:
Originally Posted by Darxide
LayinLo, you're cooler than the other side of the pillow. LOL
Offline
Old Feb 2, 2008, 08:33 PM   #5
Personal Sales Rating: (1)
kuo246's Avatar
Drives: EvoVIII
Quote:
Is the amp new?
I always mount of the box never had any problem, check the wiring
Offline
Old Feb 12, 2008, 05:34 PM   #6
Personal Sales Rating: (0)
Drives: jeep
check wiring, make sure the sub is connected at the right ohm load also, it kinda sounds like its overheating and shutting off to prevent damage.
Offline
Old Feb 12, 2008, 06:08 PM   #7
tonelock's Avatar
Drives: 06 EVO 9 MR
I Put My Amp Under The Driver Seat , It Gets A Lot Of Air And Fits Great .its A 1000 Watt Rockford Fosgate And The Amp For High's Is In The Trunk On The Side. Its An Mtx 800 Watt............after 15mins In My Car You Come Out Deaf......lol.............remember Its A Evo World....................
Offline
Old Feb 12, 2008, 06:15 PM   #8
Drives: jeep
another thing crossed my mind, if it where the vibrations of the enclosure then it wouldn't do that. i would say check the wiring to the amp.
Offline
Old Feb 12, 2008, 06:31 PM   #9
Personal Sales Rating: (28)
biggie5252's Avatar
Drives: 06 IX MR
JL / amps don't "cut out", they lower the volume when they overheat until they're cool. They also put out approximately the same power regardless of ohm load (within a certain range that is unattainable with a single w6v2 woofer) - unless the woofer itself is trash.
Offline
Old Feb 12, 2008, 06:35 PM   #10
biggie5252's Avatar
Drives: 06 IX MR
Kind of a long shot, but do you have signal sensing on the amp turned on?
Offline
Old Feb 12, 2008, 07:37 PM   #11
I don't remember, i'll have to check the specs.
But 2 things, we took the amp off the box, and the guy found a voltage sensor switch which was supposedly in the wrong position.
Now everything works good, i j/gotta adjust the settings on the amp to sound better, but the sub does not cut out anymore finally lol
__________________
Najeeb
'06 Evolution IX MR
Offline
Old Feb 12, 2008, 07:43 PM   #12
biggie5252's Avatar
Drives: 06 IX MR
Yeah, that sensor switch was what I was talking about. It's used to sense a music signal to turn the amp on if you don't have a remote turn on wire. It senses higher frequencies and if you're feeding it a crossed over sub signal then during parts of the music when there is no bass (or high enough bass) the amp will turn off because it doesn't sense any signal.
I had this problem too. The manual explains it better.
Offline
Old Feb 15, 2008, 08:33 AM   #13
xanderracing's Avatar
Drives: 2003 lancer oz rally
Send a message via AIM to xanderracing
I don't really know what to tell you... But I had kind of the same problem running 2 12" L7's with a kicker amp.
My problem was that the place my GROUND wire was hooked up too wasn't the right area.. I ended up using the bracket for my rear seats which now works well.
__________________
Everything will come around, sooner or later.
Offline
Old Feb 15, 2008, 07:46 PM   #14
There isnt much in a JL amp that would be effected by vibration. I would check to make sure you remote turn on lead wasnt loose and that you were maintaining constant power and ground to the amp.
Offline
Old Feb 21, 2008, 10:15 PM   #15
Personal Sales Rating: (11)
heel2toe's Avatar
Drives: 05 Evo SSL
I hate to repeat what has already been said however I experienced a problem similar to this and it turned out to be a poor ground. Moral of the story; grind down the paint to the metal because even though it may still work, its not the best connection and could cause problems down the road.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
