View Poll Results: Which set up would be the loudest?
Current set up...2 12" Boston g5 w/ 2 12" GTR Radiators
4 |
20.00% |
one 12w7 Ported to JL specs
12 |
60.00% |
Other
4 |
20.00% |
Oct 1, 2007, 03:15 PM
Personal Sales Rating: ( 47)
Drives: the Silver Bullet
Need help with my stereo set up....
currently i have 2 12" boston acoustic g5 subs with 2 12" gtr passive radiators running off a mtx 1501D in the spare tire well firing up. im not satisfied with the spl and want something louder. im thinking about taking them out of the spare tire well and removing my rear strut bar and then make a box where the subs can fire towards the rear of the car. would this make a big difference in sound? my other option is to get one 12w7 and port it. which set up would be the loudest? other ideas would also be appreciated. thanks!
here is what my set up looks like right now...
http://public.fotki.com/twstdevo/evo/dscn0442.html
http://public.fotki.com/twstdevo/evo/dscn0444.html
***if you choose "other" in the poll PLEASE post what you would recommend***
Offline
Oct 1, 2007, 03:23 PM
Personal Sales Rating: ( 2)
Get rid of the passive radiators for SPL applications. Going from 2 sibs to a single sub won't make a drastic difference, you'll proably lose output since the W7 probably doesn't have double the excursion of the subs you already have.
Offline
Oct 1, 2007, 03:40 PM
Personal Sales Rating: ( 24)
Drives: Evo X - GSR
How much "SPL" are you looking to get? Two G5 subs off that amp should be plenty darn loud.
Offline
Oct 1, 2007, 03:46 PM
do you guys think that the way the enclosure is set up is the reason for the lack of spl? would it be a big difference firing the subs towards the rear of the car?
Offline
Oct 1, 2007, 06:42 PM
Drives: Evo X - GSR
It's gotta be something with the enclosure design or placement. Maybe go to Circuit City or Best Buy (or order from Crutchfield) and buy one of those pre-fabbed 12" boxes that holds 2 subs. Try it out to get a feel if it sounds louder/better than your current set up. Then return the box and get your money back (I don't recommend using one of those crappy enclosures for nice subs like the G5). Then you'll know and you won't be out any money...at least until you have to build/buy a new enclosure.
Offline
Oct 1, 2007, 06:56 PM
Drives: EvolutionIX
port what you have.
__________________
WW IX GSR
SpeedElement Tuned
GTworks KW Variants 9k/11k
Offline
Oct 1, 2007, 06:59 PM
cant because the box would be larger than the space available
Offline
Oct 1, 2007, 07:18 PM
Personal Sales Rating: ( 0)
Drives: Grocery Getter
Do 1 type-r 12" in a properly ported box (pm me for proper design for this sub most use a generic method I have extensive experience with this specific sub and know what it likes for optimal performance) I guarantee it will be louder than what you have now...
Quote:
NEVER BUY A PREFAB BOX!
Offline
Oct 1, 2007, 08:13 PM
A single ported sub can be louder than a pair of subs if you want to play the only the peak note at the port tuning frequency. It will not be better listening to music.
Next, output is pressure and no matter where you put your subs they will move the same amount of air and build the same pressure in your semi sealed car interior. But.....Due to the wavelength of sub frequencies (>15 feet) there is a great deal of reflection in the car. sound waves couple or cancel and you may have standing waves at the location of your ears reducing percieved volume. The fact that you have 2 subs pressurizing and 2 radiators pressurizing makes phase problems and cancellation likely. The tradeoff is probably pretty smooth low end output.
You can try to swap the phase (+ and - speaker leads at the amp) and see what that does at the listening position. A sealed box is probably the best all around performer and much more relaible without a prooperly tuned subsonic filter.
Offline
Oct 1, 2007, 09:01 PM
You're wrong, that is why I had one of the most musical setups anyone had ever heard.... I peaked at 38hz so I could play almost anything with great output so if you would really like to put paper results up against real world results we can...
If you have 4.5 net cuft available two type-r 12's would be louder than you could ever imagine
I'm sure if you ask thecyb he will remember what team phat hertz was able to do with Type-R's in MECA
Offline
Oct 1, 2007, 10:22 PM
Drives: EvolutionIX
Your posts do nothing but show your maturity and experience level.
Thats not a compliment.
__________________
WW IX GSR
SpeedElement Tuned
Offline
Oct 1, 2007, 10:31 PM
Right former audio competitor vs someone that thinks they know what they are doing... I know nothing.
Offline
Oct 1, 2007, 10:35 PM
Drives: EvolutionIX
Former competition has what to do with real world acoustics? I guess if forgot steve brown was on EVOM.
Original poster
How much airspace do you have now? Im not a boston dealer but IIRC they dont need much.
__________________
WW IX GSR
SpeedElement Tuned
Offline
Oct 1, 2007, 10:43 PM
Original poster
Next time you try to insult me make sure you spell everything properly otherwise it makes you look like just as much of an ass as you are trying to make me.
A former car audio competitor of course has no knowledge of real world acoustics  . What a formula says and what actually happens in a vehicular atmosphere are two different things...
If he wants to be louder he needs to port and if he doesn't have a minimum of 2cuft net per sub then he shouldn't waste his time. I know plenty of installers such as yourself that think they know everything there is to know when in reality they know as little as one that works for circuit city or best buy...
Just because you know manufacture specs and how to install something doesn't mean you know how to do it properly
Offline
Oct 1, 2007, 10:57 PM
well i got 2cf sealed now, if i change the set up to have the subs firing back towards the rear of the car, im open to as much airspace as long as i can take the box out. i figured 2cf is as much as i can go in order to be able to take the box out, so thats why im asking if 1 12 ported (whether a 12w7 or anything that would be best with the 1501D) is better than the 2 sealed. im open to suggestions and appreciate everyone's help, i really want to create the best and loudest set up that can be removed.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
