Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 1, 2007, 06:03 AM   #1
Personal Sales Rating: (3)
shimla's Avatar
need help w/ cigar lighter fuse blowing
this might be OT but here goes:
I hooked up 2 accessories to my cig lighter outlet at the same time.
Radar detector and other one is a portable air compressor w/c after a few sec of usage, my fuse blew up and came w/ it a foul smell inside the cabin.
I replaced the 15A fuse twice but everytime I plug in the radar detector(only), the fuse kept on blowing up .
PLs help on what to do next?
Thanks!!!
__________________
Kuniiizzzeee Dial-IN
Offline
Old Oct 1, 2007, 02:35 PM   #2
Personal Sales Rating: (27)
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
Can you plug anything else in there and get it to work with out blowing a fuse? If so I would say either the cable to the radar detector is shorted or the radar detector itself is shorted...
Offline
Old Oct 1, 2007, 03:03 PM   #3
Personal Sales Rating: (1)
buddha1320's Avatar
Drives: 03 Evo VIII
make nsure your connection is not grounding up somewhere or getting pinched
__________________
Be whatever you want to be.... but be the best.
4 horsemen
Offline
Old Oct 2, 2007, 05:55 AM   #4
shimla's Avatar
i tried plugging even the just the phone charger w/ a small LED and the fuse would still blow up.
__________________
Offline
Old Oct 2, 2007, 10:04 AM   #5
Personal Sales Rating: (4)
does the fuse blow only when you plug something in, or with everything unplugged does it still blow? I have ran into a problem once where there was two small strands of wire that dropped into the lighter, no biggie until something was plugged in, then it would short.
Offline
Old Oct 2, 2007, 10:11 AM   #6
Get a multimeter and put it on volts DC. Take the wires off the back of the cig lighter and put the black probe on the wire that was on the outer conductor of the lighter and the red probe on the wire that went to the center conductor of the lighter. This should read around 12 volts. If it reads way high you have a short somewhere. Also may have a shorted cig lighter assembly. If that is the case you can pick on up from autozone for cheap and replace it. They just screw in...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
