Sep 2, 2007, 01:46 PM
Personal Sales Rating: ( 3)
Drives: 2006 EVO IX GSR GG
Power wire?
Just wanted to know what you guys are using as far as wire brands, ex Monster, Stinger,...
Is a brand better than another? Which one is preferable? What to look for in a wire?
Also, what RCA's are you guys running.
TY
__________________
No sig, MMNA and EvoM mods are watching.....
Offline
Sep 2, 2007, 04:08 PM
Drives: 06 Evo IX MR
I use Lightning Audio Power wire in 2 gauge. Look for # of strands, flexibility and thickness of insulation.
As for RCAs, I use Planet Waves Cable Station cables which can be cut to length, and built at home with solderless connections.
I have 10 RCA wires in my car, and because they are custom lengths. I can route them away from power cables and make them as short as possible.
I have run monster RCAs (Jesus Christ how expensive), and Rockford Fosgate, but these Cable Station wires are by far my favorite... and I have ZERO noise.
__________________
Austin T
Dual Sub Box project completed. Thank you Matt and Wicked Car Audio Systems.
"The winner is not always the fastest, but always the one who slows down the least"
"races are won in the corners"
Offline
Sep 2, 2007, 05:59 PM
Any idea on specs of what I would need to look for? Ex. # of strands?
__________________
Offline
Sep 2, 2007, 06:04 PM
Personal Sales Rating: ( 16)
Drives: EVO VIII RS
If your not as die hard as the other poster above, you could grab any 4 gauge wire and something decent (brand name youve heard of) from a stereo shop for your install. I had 2 12" audiobahns and a memphis class d amp. I had no noise and plenty of sound. I actually took it out cuz it rattled the back of my car loose, and I hate rattles!!! haha
__________________
__________________________________________________
--------------- Tuned by "ONRAILS" ---------------
__________________________________________________ _
Offline
Sep 2, 2007, 06:17 PM
My setup is going to be 2 arc audio amps, 300.4 and 300.2, Morel Dotech Ovations and 1 12" Arc Audio sub in sealed enclosure.
I do not want to skimp out on rca's and wire and make the system sound not as it should be.
__________________
Offline
Sep 2, 2007, 07:57 PM
Personal Sales Rating: ( 10)
Drives: 06 WW IX
I have JL power wire and the blue series rcas, worked awesome for me!
Offline
Sep 3, 2007, 12:18 AM
Personal Sales Rating: ( 1)
Drives: 03 Evo VIII
i have all tsunami wires
__________________
Be whatever you want to be.... but be the best.
4 horsemen
Offline
Sep 3, 2007, 03:22 AM
The other poster is correct. Power wire is Power wire. I am dealing with 1400W in my Evo... If you are under that, the power wire is not as critical.
Just go down to your local audio shop and see what they use in their installs. JL wire is good as well :-)
__________________
Austin T
Offline
Sep 3, 2007, 06:23 AM
Personal Sales Rating: ( 9)
Drives: Gixxa, 03 TB VIII
I have JL. They are good. Fosgate are good too.
You can't go wrong with most of the major companies.
You also have to realize what type of car this nice set-up is going in. Unless you have completely sound dampened your car and have the stock exhaust and stay under 3000 rpms, you are never going to experience the high fidelity of this system. Unless you only listen to it in the driveway.
Not busting your hump, but the Evo is super noisy.
Good luck in your search, and please let us know what you finally decide to run. Pics are always a plus!
BTW, you have nice taste in audio equipment.
__________________
Yes . . . that's me on the bike.
Quote:
Originally Posted by Darxide
LayinLo, you're cooler than the other side of the pillow. LOL
Offline
Sep 3, 2007, 09:17 AM
Drives: 05 RS, '04 G35, '91 300zxTT, '04 GSXR 600
Like others have said, just go with a brand that you have heard of before and you can get from a STEREO shop. I've seen countless autozone, walmart, ebay amp kits come through the shop. The other day a guy came in with a LANZAR 1000 watt amp kit. Cut the end of the power wire off, looked like speaker wire coated with enough insulation to make it the size of 4 gauge
Offline
Sep 3, 2007, 12:12 PM
LayinLo, thank you.
I will probably end up going with JL. Will know for sure at the end of the week.
__________________
Offline
Sep 3, 2007, 12:21 PM
Drives: 2003 Evo VIII
Don't just use anything, Most companys measure the thickness by the overall diameter. Some of those walmart kits are 4 gauge but the copper inside isn't as thick. Our shop sells Rockford Fosgate, their newest stuff is nice. I personally use Stinger Expert Series. One of the best out there, more strands then most, crazy flexible and plain looking. Plain flat gray for power, flat black for ground. Blends in nicely.
As far as RCA's. Tough call, most companys make great RCA's and then they also sell cheap RCA's. You pay for what you get. I use Monster b/c thats what our shop sells but they are kinda pricey.
__________________
302.4 AWHP DynoDynamics Dyno
HKS 272/272 Cams,
Ported & Swaintech Coated Stock Mani
Exedy Stage 3 Twin Disk Clutch
Exedy Chromemoly Flywheel
Vishnu Xede w/ SMART
Cobb SF Intake, Helix I/c Pipes
AMS Front Mount Intercooler
EPM O2 Dump (Swain Coated)
FP 10.5 Single Flapper Hotside (Swain Coated)
Buschlar SS Downpipe (Swain Coated
Greddy Ti Exhaust, Helix HF Cat
Tein S Springs, Hotchkis Rear Sway Bar
255 Fuel Pump, AMS Fuel Rail
Offline
Sep 7, 2007, 07:23 AM
Personal Sales Rating: ( 0)
Drives: VIII MR
In terms of power wire and speaker wire, KnuKoncepts has a pretty good bang for the buck. Good quality and flexibility at a decent price. the downside is having to order online and estimate/guess about how much you need. IIRC they have an eBay store in addition to their website.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
