Aug 22, 2007, 06:03 PM
Personal Sales Rating: ( 0)
Drives: EVO MR IX
Alarm Add On's???
I've got my mind set on the Compustar P2W9000FM-AS.
1) Is the standard security equipment sufficient or more add on's are needed to make the system more robust?
2) If additional security equipment is needed, what are they?
3) What additional equipment/feature is necessary and what's going overboard?
Thanks!
Offline
Aug 22, 2007, 07:27 PM
Personal Sales Rating: ( 82)
Drives: 2006 Evo IX MR SE
i recommend battery backup. i am getting mine installed tomorrow. i will let you know how it goes. by the way, i noticed you are getting the AS which means you want the alarm and remote starter. that means you will have to give up your 2nd key.
Offline
Aug 22, 2007, 08:10 PM
Drives: Grocery Getter
Quote:
I would recommend adding additional peizo's.
Offline
Aug 22, 2007, 08:12 PM
is a peizo a sensor? if so, what kind of sensors are you suggesting?
Offline
Aug 22, 2007, 08:53 PM
peizo is a siren.
Offline
Aug 22, 2007, 09:18 PM
the installer told me there is a siren that does not turn off even if it is smashed and if power is removed from it. have you heard of it?
Offline
Aug 22, 2007, 09:54 PM
I haven't but I don't play around with alarms much.
Offline
Aug 22, 2007, 10:33 PM
Forgot to mention I would get glass break sensors, as well as a tilt sensor so you know if someone is trying to take your car via flatbed.
Offline
Aug 23, 2007, 05:42 AM
Personal Sales Rating: ( 2)
Drives: 2003 honda pilot ex,1988 6G72 V6mitsubishi galant 200,500+miles, 2002 honda civic, 2003 IS300 black, 2006 evoix mr gg
..... that means you will have to give up your 2nd key.
not true, I still have my 2nd key. buy the transponder bypass PKU MIT from bypasskit.com(12voltshop.com=store).
add 507t and 508d
__________________
avatar: 1976 mitsubishi lancer evom#249
RIP Mark(KK)
Quote:
Originally Posted by oldscholevo
i know my 04 sti was govern at 149, and I thought that evo is the same thing??
Quote:
Originally Posted by DynoFlash
I will say this
This car (evo X) will need 400 whp to beat a Evo IX with 260 whp
The X feels very heavy - although it certainly handles very well
scammed? click here http://forums.evolutionm.net/evom-an...-alert-24.html
Offline
Aug 23, 2007, 01:24 PM
you can always just have an additional key made as well.
Offline
Aug 23, 2007, 01:26 PM
Drives: EVO MR IX
What does the transponder bypass PKU MIT do?
Offline
Aug 23, 2007, 03:31 PM
i think it will allow the car to think that the key is in the ignition, so that the remote start will work, since the key has a chip in it.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
