Mar 30, 2007, 05:21 PM
Personal Sales Rating: ( 1)
Drives: 2006 Evolution RS WW
Getting some sound into my RS, Please Help!
hey guys i have an evo9 rs, first question is are all the speakers prewired for sound? what about the head unit? what is that white connector i see attached to the block off plate? if it is prewired than what type of speaker/size should i get in order for it to plug and play, whats a good set that will give me some bump without the need of a sub.
Offline
Mar 30, 2007, 06:19 PM
Personal Sales Rating: ( 0)
Drives: 04 evo rs
everything is there prewired just buy a deck and some speakers(not sure the size).
Offline
Mar 30, 2007, 06:27 PM
Drives: 08 TR VW GTI
Yes the White wires going to the Block off plate is the harness for the Radio. I would suggest Circuit City and buy the Harness from OEM -> Whatever brand head Unit you buy. It saves a lot of time!
As for the speakers they are 6 3/4". If you use Apline Type S 6.5" they come with a bracket so they will work no problem. Then you just have to solder the speaker connects and plaug them in!
Offline
Mar 31, 2007, 12:24 AM
thanks for the info, so its 6 3/4 fronts and rears?
Offline
Mar 31, 2007, 05:32 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Quote:
yup
Offline
Apr 2, 2007, 03:34 PM
Quote:
Originally Posted by ThunderOZRacer
yup
i went to circuit city today and they told me its 6 1/2 all around.
Offline
Apr 4, 2007, 11:13 AM
Generally, a 6.5" speaker has a mounting plate for a 6.5-6.75" hole. You can run a 6.5" as long as it has a compatible mounting plate for the 6.75" hole. ie, Pioneer, Polk Audio, Alpine, etc, etc.
Offline
Apr 5, 2007, 02:26 PM
Quote:
gotcha, on another note when i proceeded to plug the wire into the speakers it wont match, do i need some sort of of speaker harness?
Offline
Apr 5, 2007, 02:32 PM
Personal Sales Rating: ( 27)
Drives: 05 WW EVO RS
You need to basicly cut it and make new connection. They wont fit because the harness is for stock evo/lancer speakers . I went thru same **** because i own RS
as far for aftermarket radio you need a harness plug/play for regular lancer, they fit. I think harness is like $10 bux, No harness is required if ur using stock evo/lancer radio.
GL!
__________________
05 RS....Powered by Big Turbo, 2.0 build in progress /// APM RACiNG
Offline
Apr 5, 2007, 03:59 PM
GL!
there are no adapters that i can buy, i dont like the idea of cutting the stock wires.
Offline
Apr 5, 2007, 04:58 PM
Drives: Lancer Evolution VIII
i used to have a 3000gt and if that is similar at all to the evo, when you cut the wires, and get a harness the wires are all the same color so your shouldn't have a problem connecting them.
__________________
RS*R 3" Turboback Exhaust
Evo MR BOV
Cusco Rear Sway Bar
Vishnu Adjustable Cam Gears
Injen Upper IC Piping
Injen Lower IC Piping
Injen Intake
Lowering Springs
Evo 7 JDM Taillights
Alpine Deck w/ Ipod Connector
Shorty Antenna
Offline
Apr 5, 2007, 07:13 PM
Personal Sales Rating: ( 2)
Drives: an Apex Silver one
if you don't care too much about sound quality, I would just buy stock Lancer/evo speakers and unit off EvoM...cheap and direct plug and play...no worries about fitment...
__________________
WTB - Front LSD, OEM or aftermarket, new or used.
ARC box, Zeal 10/10, RRE sway bar, Cusco rear bar, JDM MR DV, Zero-Lift front dam
Quote:
Originally Posted by SilverNine
OMG!!!!! i am going to either kill myself or sum1 else for me being so f_cking stupid!!! Blonde im SORRY but i DONT have Boardwalk!!!!
Offline
Apr 5, 2007, 07:18 PM
They do sell direct connections for the factory harnesses. Crutchfield.com would be the place to contact. They offer them free with all of their speaker purchases. If you can avoid cutting the factory harness, I would. Especially in a new car.
http://www.crutchfield.com/S-4ntX26c...99&cc=01&wm=tn
Follow the link and see what your after.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
