Bought a car with an alarm already installed
Well, I picked up a used car today...daily driver to keep the Evo safe on nasty days. Anyway, it has an alarm on it, I discovered today. All I have is a key, no remote or anything to deactivate it.
So, when you stick the key in the door and turn it to lock, it arms the alarm (and kill switch), when you unlock the door, it doesn't turn it off, but it doesn't set the alarm off either when you open the door....it just won't start. If you lock the door by pushing the lock down from the inside, then shut it, the alarm does not arm itself.
My question....assuming the dealership doesn't have the remote that goes with this thing, any idea on how it might otherwise disarm? I had to put the key in the ignition, turn it to ON, disconnect the battery, then reconnect the battery to get it to bypass arming and get the car started. I'd like to use it if at all possible. Can an alarm shop provide a new remote matched to the system? Or, worst case, just cut the power to the thing just do without?
Just looking at my options.
__________________
Quote:
Originally Posted by 22stars
there should be no doubt in your minds that i will go retard strong for some cake.
Quote:
Originally Posted by Xx Danny xX
One time a drunk guy at a bar bumped into me causing me to spill my beer all over my shirt. So, I raped him...and his girlfriend...in that order. I don't play around when it comes to wasting alcohol.
Quote:
Originally Posted by thechoc
why is there an Aztec in my thread
