Mar 12, 2007, 10:14 AM
Personal Sales Rating: ( 2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
Attaching dowels to the inside of the box?
What do you all use to attach them? I was going to take small blocks of wood and glue them to the inside of the box somehow and then drill out 3/8" holes that the dowels can go into and be glued into place. Any other ideas?
Offline
Mar 12, 2007, 03:16 PM
damn.. nothing at all? lol
Offline
Mar 12, 2007, 08:42 PM
just wanted to post one more time to get to 100 posts... ok did it lol.
Offline
Mar 13, 2007, 02:20 PM
bump! Please people, I need some help here lol.
Offline
Mar 13, 2007, 02:48 PM
Personal Sales Rating: ( 4)
what are you doing this for?
Offline
Mar 13, 2007, 02:49 PM
Personal Sales Rating: ( 10)
Drives: with your girl's head in my lap..
Quote:
+1 what are u doing???
__________________
IVEY TUNED 2006 GraphiteGray Evolution IX SE
Offline
Mar 13, 2007, 02:57 PM
i'm making a fiberglass enclosure... but I need to know how to attach the dowels to the inside of the box to hold the ring in place.
Offline
Mar 13, 2007, 03:02 PM
Personal Sales Rating: ( 33)
Drives: 04 EVO VIII - Tarmac
you can use a bunch of different things. The best thing to use is a 3m adhesive called insta glue...
Apply the adhsive, then spray the activator and 3 seconds later its stuck like super glue...
Offline
Mar 13, 2007, 03:06 PM
I would use hot glue.. but the ring is pretty heavy and is going to be mounted sort of up at an angle, so glue alone isn't going to do it without some sort of stabilizer dowels.
Offline
Mar 13, 2007, 03:18 PM
umm, insta glue is what you want to use. Its what I just used to hold the ring for our custom kicker solo x sub....it will hold much, much better than hot glue....trust me
There is a reason its 20.00 for a couple ounces...
Offline
Mar 13, 2007, 03:19 PM
ok, I just undertshand your confusion....you still need to use the dowels initially. But you can remove them after the top layers have been put on....sorry for the confusion..
Offline
Mar 13, 2007, 03:20 PM
really? so the resin will hold the ring in place?
Offline
Mar 13, 2007, 03:36 PM
Yes, the resin and fiberglass should if you use enough layers (7)..
depends on your application (what type of sub your installing)
The kicker solo x enclosure needs at least 1" think mdf or fiberglass....yea, it took some time
Offline
Mar 13, 2007, 04:49 PM
it's a RF he 12". I don't understand how that resin could hold that ring in place just by sticking to the top of the ring though.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
