Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 4, 2007, 09:29 PM   #1
Personal Sales Rating: (2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
Fiberglass sub box.. do you have to use mat?
Just wondering if you have to use fiberglass matting to build a box? I have some pretty thick woven stuff that I was going to cut into small pieces and use. I don't see how it would really matter though.. opinions?
Offline
Old Mar 4, 2007, 09:58 PM   #2
Personal Sales Rating: (14)
TheShortBus's Avatar
Drives: R.I.P. Turbo '03 Lancer... NOW '04 WRX
Send a message via AIM to TheShortBus
im guessing you just have fiberglass cloth.
i like it much better then mat because you dont have to deal with all the hairs.
__________________
16g Turbo Build
Offline
Old Mar 4, 2007, 10:07 PM   #3
Personal Sales Rating: (12)
badhabit90's Avatar
Drives: '04 'mac black EVO8, '04 black onyx IS300, 1998 eclipse gst(R.I.P.), 1993 Honda Accord A.E., 1990 Ford Mustang-built 302(sold), 1971 Chevy Elco built 307
Cool
Quote:
no you dont have to. the woven stuff is usually more money that is why people use the matting. it does help however to use matting in corners and such to help strenghthen them up where the woven is thinner.
i used to use the woven stuff when i would make my kick panels for my competitions.
__________________
Helix intercooler pipes,Helix 3" DP,Helix 3" exhaust,Invidia o2,Helix DNA coilovers, WORKS filter,3" WORKS HFC,Greddy Type S,FPWR Turbo w/Ti internals,10.5 Hotside,Works p2 flash w/boost control, Works 269 cams,Revolver valvesprings/retainers,ARP headstuds,Walbro 255,6000k HID upgrade,DoLuck CF lip,Omori multicolor electronic 60mm gauges,B&M short shifter,Pocketlogger,HKS type 1 TT,custom grounding kit,voltage stabilizer,Axas shift indicator light
Offline
Old Mar 5, 2007, 11:34 AM   #4
Once I had a mold made I would use both cloth and mat so there was no resin buildup and weak spots.
The first layer would be mat, rip it apart, don't cut clean lines. Before it dries completely put down a layer of mat followed up with dry cloth to absorb any excess resin. Dpending on the shape and application, repeat as necessary.
Offline
Old Mar 5, 2007, 01:54 PM   #5
I had bought a whole gallon of boatyard resin sometime last year and I got my trunk all lined with tape and foil and had it ready and started putting down the resin and the cloth and then waited... and waited.... and waited... and it never would dry. I think from being in the garage and being so cold and hot it ruined it. I just got some new bondo resin now... it's drying fine now though. I guess i'll do 2 coats and then pull the form out and start reinforcing it with more cloth and such.
Offline
Old Mar 5, 2007, 02:06 PM   #6
You did put hardener in it right? Was the mix rate correct? Resin should be stored at room temp but I had plenty get cold in 55 gallon drums overnight without a problem.
Another clue: Go to a hobby store adn buy Rigid Wrap. It is the plaster cloth they use for making scenery in model train setups. It is water soluable, odor free and dries fast. Lay that in the car to make a firm mold in the shape you want. When it dries, remove it and glass the inside out of the car. no resin smell, mess an its easier to work on it and get even glass distribution.
Offline
Old Mar 5, 2007, 02:19 PM   #7
that's awesome man... I will definitely check that stuff out... unfortunately i've already gotten a lot of the mold finished.. but I will probably do the other side too and I will have to use that stuff.
I'm pretty sure I put enough hardener in the stuff. Honestly it could have been off a bit... but now i'm scared to try it because I don't want to mess up my current mold job. I will have to try a correct ratio in a very small portion to make sure it is actually bad. I'd love it if it wasn't since that stuff isn't cheap!
Offline
Old Mar 5, 2007, 02:38 PM   #8
The mix rate is very important for curing and strength
Offline
Old Mar 5, 2007, 09:22 PM   #9
Silver Sponsor
Personal Sales Rating: (4)
Drives: 06 Evo MR
the different mats are for different points in a mold (most of the time) the thin "chop mat" is best used to get small contours since it can be torn into smaller pieces and the thicker "weave" when soaked right dries hard as concrete. If you were doing a section that is mostly flat, the weave would be best and the mat comes in different weights or thicknesses to build up quicker.
Offline
Old Mar 6, 2007, 04:33 AM   #10
The reason we always layer both was that the mat tends to hold more resin and the resin itself provides no strength. A layer of cloth will also give you a better surface to bond to for the next layer. If you set up the job properly the whole process will go pretty quickly if you hvae a good mold.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
