Feb 18, 2007, 11:54 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evo MR Rally Red
Amp Locations
Where have you guys mounted your amps?
__________________
- Greddy Titanium Exhaust
- WORKS RTP
- WORKS Exhale DP 76mm
- WORKS High-Flow Drop-In Air Filter
- 5% 3M window tint
Offline
Feb 19, 2007, 12:53 AM
Personal Sales Rating: ( 15)
Drives: VIII RS
on my viii and going on my ix, bolting up two amps on the "V" stock brace of the trunk thru panel. You'll see it when you take the cover off. Measure and drill for vertical installs. Frees up a lot of room on the trunk floor. I then put back the rear strut bar which act as barrier against damage to the amps.
when you bolt up the amps, pre drill the brace and the carpeted cover. Put back the cover then bolt the amps for clean install. You can snake all the wiring to the trunk corner from interior flooring.
I'll have to post the pics when I'm finally done. It's taking forever!!!
BTW, make sure you pick lighter amps! I got two Eclipse newer amps. Small footprint and light!
Offline
Feb 19, 2007, 01:11 AM
Personal Sales Rating: ( 20)
Drives: 2006 EVO IX
Please do post pics spyderx, I'ld like to see what you did.
__________________
2006 Evo IX
GSC S1 Cams // Megan TBE // PTE 1000cc Injectors // Apexi Filter // Perrin FMIC // AMS LICP // ETS UICP // Walbro Pump // Hallman MBC // ACT HDG6 Clutch + ACT Streetlite Flywheel // BC Coilovers // Blox Front Mount
"We are what we repeatedly do. Excellence, therefore, is not an act, but a habit." -- Aristotle
Offline
Feb 19, 2007, 01:55 AM
Drives: EvolutionIX
__________________
WW IX GSR
SpeedElement Tuned
GTworks KW Variants 9k/11k
Offline
Feb 19, 2007, 06:59 AM
Personal Sales Rating: ( 33)
Drives: 04 EVO VIII - Tarmac
under the front seats for ease of install and looks...
Offline
Feb 19, 2007, 07:04 AM
Personal Sales Rating: ( 1)
Drives: EVO IX
under the front seat there is a lot of space and easy to work in that area
__________________
12.36@95 mph (bracket racing)
Fuel Pump
K&N drop in
DP, o2, Catless & exhaust
Reflash
MBC
Offline
Feb 19, 2007, 12:23 PM
Personal Sales Rating: ( 8)
Drives: AS IX
^ I also got'em under the seats. It's nice to have 1000 watts under my ass and 600 watts under my girls ass!
__________________
JDMChicago.com
Offline
Feb 19, 2007, 09:09 PM
Drives: VIII RS
Quote:
Same style install like the pic above, except I have two amps.
Offline
Feb 20, 2007, 04:21 PM
Drives: IX FQ360
box is 26L and only weighs 4kg.
Offline
Feb 20, 2007, 08:02 PM
Personal Sales Rating: ( 0)
Drives: Evolution 8
On my first system i had them on both sidez of my trunk, on my second system after they stole my first one i did it custom i got a foot and a half of trunk space but it lookz good and soundz real good i'll post pictures when i got some time!
You guyz also gotta remember when you got your ampz covered up your not letting any ventilation into them and they get hot and don't respond the right way.
Offline
Feb 20, 2007, 08:35 PM
Drives: EvolutionIX
Quote:
two words homie
zip ties
__________________
WW IX GSR
SpeedElement Tuned
Offline
Feb 20, 2007, 08:37 PM
Personal Sales Rating: ( 10)
Drives: with your girl's head in my lap..
i mounted my amp onto my sub box.. i like the way it looks i can post pics up on fri if u want..
__________________
IVEY TUNED 2006 GraphiteGray Evolution IX SE
Offline
Feb 21, 2007, 12:31 PM
Drives: IX FQ360
Quote:
Originally Posted by DontRevMe
two words homie
zip ties
I've bolted it from the front (2 bolts) and also 3 brackets at the rear (top of box) onto support underneath parcel shelf (I think OEM strut brace), afterall this car can cornor fast
Offline
Feb 21, 2007, 12:36 PM
Drives: IX FQ360
:d
Offline
Feb 24, 2007, 11:59 AM
Drives: 08 PB X, 97 Civic, 06 R1
ive got my amps mounted like this
still not done yet, i made a cover for them that you can see on my post below of my system as i am working on it....
Back to work - Stereo Install
__________________
Plot... Plot... Plot......Plot..Plot............NO MORE!
......back to square 1......
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
