Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2006, 08:45 PM   #1
Personal Sales Rating: (18)
mike127's Avatar
Drives: 06 GG IX
Question Installing gauge kit on GSR
Anyone know if there is a kit for installing the factory gauge kit in the lower opening on a GSR ( in place of the "change" tray)? It doesn't seem to have the bracket necesary to mount the four screws to.
Mike
Offline
Old Nov 9, 2006, 08:58 PM   #2
Personal Sales Rating: (14)
evo72man's Avatar
Drives: 2003 EVO
If you unscrew it, I believe there is four screw holes. Thats where I installed my gauges.
__________________
Wooooooshhhhhhhhhhhhhhhhh
SARD 660cc injectors, SARD 255cc fuel pump, Buddy Club Cams 264/272, HKS Gears, 3'' Turbo Back Exhaust, Dyno Tuned at 23 psi, EVO 9 BOV, K&N Drop in filter, HKS Down Pipe.
Offline
Old Nov 26, 2006, 06:18 PM   #3
mike127's Avatar
Drives: 06 GG IX
Smile
Bringing this one back from the dead! If I place the OE sports meter gauge kit in the lower opening on a GSR (where the change tray is), I assume i would then need the black plastic housing that surrounds the gauge kit on an MR and RS. Does anyone know the part number on this piece, as the radio relocation piece only works for a radio, not the OE gauge pack. Thanks. I'll post this in part number requests, also.
Mike
Offline
Old Nov 30, 2006, 05:36 PM   #4
evo72man's Avatar
Drives: 2003 EVO
I think it would be easier if you mount the OEM gauge set in the spot where the factory radio is. It bolts right in. Then if you have an after market radio put the can where the radio slides into the bottom portion of where the change holder is using a relocation kit. That is what I did. But if you want to you can also bolt the factory radio into the relocation kit. The kit is like $50, you will need the kit either way.
__________________
Offline
Old Nov 30, 2006, 05:49 PM   #5
mike127's Avatar
Drives: 06 GG IX
Smile
Thanks for the info! I have the radio relo kit but I would like to put the gauges on the bottom. There seems to be a large space between the mounted gauges and the black plastic trim piece. Are the gauges in the MR and RS's mounted directly to the trim piece or are they mounted differently so they sit flush behind the trim piece? Anybody with an MR or Rs that has relocated the gauges to the top can probably answer this one, hopefully!
Mike
Offline
Old Jul 24, 2007, 09:33 PM   #6
Personal Sales Rating: (0)
KOM88's Avatar
Drives: EVOLUTION VIII
they are mounted like a normal gauge.... there is a nut on the back that holds a retaing clip to the (also on back) panel. so in other words, they are flush mounted, and you can easily move them around from spot to spot.
__________________
tinted windows//alpine cd player//with i pod control//NOS stickers//new car scent air freshner//purple neons// evolution license plate frame and valve caps//walmart tires on special $76 dollars for fronts. then i got bigger ones in the back ($78 not on special) so it looks like a muscel car//super custom painted all of the plastic of my interior bright orange and re upohlostered the headliner in zebra print//took 2x4's and raised the wing about a foot higher (for down force at super high speeds)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
