Nov 1, 2006, 11:44 AM
Personal Sales Rating: ( 36)
Drives: like I've got a pair.
Anyone know where to get a High-Output Alternator for the Evo?
I'm sure there are more than a few of you out there with "mild to wild" stereo upgrades in your Evo's, and for the knowledgable, that means someone out there knows which company can provide an upgraded alternator for the 06 4G63.
My own stereo isn't huge --- just upgraded speakers and deck with a 1000 watt amp and an Alpine R-12 in a custom fiberglass enclosure. I know that I may not be pushing the envelope of what's considered to be "in need" of an alternator upgrade, but I'm just covering my arse.
Who makes these for the Evo?
__________________
Current Mods:
BR 2.0, Stage 3 head, FPred @ 39psi, Ptd/ctd Exh. mani, Ported Intake mani, WORKS 76mm DP w/ RTP, Tanabe Touring Medallion, Apexi filter, APS twin-vent, Aperture II TB, Cossie M2's, JAM lifters, BR Double Pumper, PTE 1200's, AMS fuel rail, Sparktech non-CDI, ETS LICP, Perrin FMIC, ETS UICP, Irragi HO Alt, Hallman Pro RX, Beatrush + CROX II, Whiteline kit, Tanabe Pro 5's, WORKS rear strut bar, LC-1, Defi's, JDM rear, UK badge, SE lip, Volk's, 522/473 on E85.
Tuned by Mellon
Offline
Nov 8, 2006, 08:34 PM
Personal Sales Rating: ( 11)
Drives: WW IX RS
the ssl evo's come w/ upgraded alternator...I don't know the rated amp's or part# though.
Offline
Nov 12, 2006, 03:12 PM
Personal Sales Rating: ( 12)
Drives: 06 GG MR, 08 Acura TL type-s, 03 CBR 954rr, 01 Celica GT
When I was audio crazy, I used a company called "ohio generator" They have pre-fabbed high output alternators, or I believe they will upgrade your stocker. You ship it to them and they up grade it. *if I'm remembering correctly, google them and check it out. Sounds like you are just in the neighborhood of needing a stiffening cap though.
Offline
Nov 12, 2006, 05:50 PM
Personal Sales Rating: ( 0)
Drives: 2005 EVO VIII GSR
ralliart japan makes one specifically for the evo, but it's set at a ridiculous price at approximately $1000. I'm pushing 3000 RMS and still using the stock alternator....I see how it goes for now cuz don't want to waste anymore money.
Offline
Nov 12, 2006, 05:58 PM
Personal Sales Rating: ( 3)
Drives: DSG Pleasure-Evo Race car
I have a ralliart Alternator if you're interested. 125amp. Retail is 1650. I will let it go for 1300.
PM me if you want it.
Offline
Nov 12, 2006, 05:59 PM
Personal Sales Rating: ( 2)
Drives: 04 EVO 8
subcribed.
__________________
Half the engine....Twice the FUN!!
Offline
Nov 12, 2006, 07:21 PM
Drives: EvolutionIX
1300 for an alternator?
uhhhh,...you can call stinger and have them make you one for 500~ that will do more like 250 amps.
__________________
WW IX GSR
SpeedElement Tuned
GTworks KW Variants 9k/11k
Offline
Nov 12, 2006, 07:25 PM
You can get them cheaper from a lot of places. I'm just throwing that out there.
Offline
Nov 22, 2006, 01:01 AM
Drives: like a champ
...whats wrong with adding a second battery? optima yellow top seems to be the most prefered.....btw do any of you guys know the specs for interior speakers?
__________________
Quote:
Originally Posted by gregivq
apparently you can't even upload pics...your signature doesn't work
Offline
Nov 22, 2006, 07:01 AM
Personal Sales Rating: ( 86)
7 years ago I built a stereo with 30 amp fuse front amp and 60 amp fuse sub amp. This would be a pretty mild stereo in todays standards. I was after sound quality. The stock alternator was 90 amps. With the car needing 40amps or so to run, this leaves a big defficiency. Caps dont do ****, extra batterry is very temporaray (maybe 15-20 minutes). Whats needed is more current. The current DOES come form the alternator. The battery is only a storage cell. I installed a 145 amp alternator from a caddy. The difference is sound quality after the alt was nothing short of AMAZING. Do the math people. Just add the fuse rating on your amps. You need that plus at least 50 for the car.
__________________
early evo nut rockin
evo1 and evo 4
Online
Nov 22, 2006, 07:41 AM
Personal Sales Rating: ( 5)
Drives: 2008 Lexus IS-F
Someone said that the SSL Evo has an upgraded alternator, is that true? What's the rating for it? I have an 05 SSL Evo with upgraded stereo, 1 mono block amp pushing 1000W RMS and a 4-channel amp pushing 250W RMS x 4. When I up the volume my dashboard lights start to dim following the low notes, headlights are fine as well as RPM. Caps do nothing, so I was thinking about upgrading my alternator, is there any other thing that can be done, maybe the big three?
Offline
Nov 22, 2006, 09:00 AM
Personal Sales Rating: ( 6)
Good info.
Offline
Nov 23, 2006, 08:38 AM
Drives: evo VIII 2003
www.extremeaudio.biz you can buy a stinger 200amp (920) 684-0996
Offline
Apr 12, 2007, 07:53 AM
Drives: 04 EVO 8
does anyone have a higher output alternator. Just installed my system, 4/150 and 1/1000 with a batcap 400 and lights are still dimming.
__________________
Offline
Apr 14, 2007, 05:53 AM
Personal Sales Rating: ( 7)
Drives: On The Wrong Side of the Fence
depending on your location. there are usually alternator/battery specialists that can respin the stock alternator or make custom brackets to retrofit a larger unit.
service around here goes for 200-700 depending on what you need.
i would suggest you call your local car audio shops and ask them who does the best alternator work. call around until you here the same name a couple of times.
Offline
Tags
1000, alternator, alternators, amp, companies, custom, evo, evolution, high, miami, output, rating, swap, top, true, watt  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
