Quote:
Originally Posted by st3alth5
- make sure you have the rest of the materials you need for the install (cable to go from the receiver to the amp and wire to go from the amp to the sub)
- figure out where you plan to run all of the cables and wires before you start
- make sure you have plenty of tools at your disposal for your plan (a drill if you are going to drill through the firewall, a multimeter can also be handy to have)
- plan to spend an entire day doing this
- avoid drilling through the firewall, unless you have plans for other things to go through the factory placed grommets
- do not run the audio signal lines next to the power line
Nothing wrong with drilling a new hole in the firewall, use a new grommet.
In a bass only application, it doesnt make any difference to separate power from signal.
You can have the battery hooked up during install, but dont install the new fuse untill all of you connections are complete. Your ground M U S T be on a PAINT FREE metal surface, and i dont mean sheetmetal. Check for gas tanks before screwing anything down.
if you have any questions Hit me up on aim.
dontrevme.
