Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 11, 2006, 10:32 PM   #1
Personal Sales Rating: (20)
Inprogress's Avatar
Drives: 2006 EVO IX
Send a message via AIM to Inprogress
Installing iPod module, had a question...
I have to run a ground a 12v power source for the module, so I was wondering where I would have access to this behind the headunit ? I'm not worried about the ground, I'm thinking about hooking it up to the headunit's support bracket. but what about power?
__________________
2006 Evo IX
GSC S1 Cams // Megan TBE // PTE 1000cc Injectors // Apexi Filter // Perrin FMIC // AMS LICP // ETS UICP // Walbro Pump // Hallman MBC // ACT HDG6 Clutch + ACT Streetlite Flywheel // BC Coilovers // Blox Front Mount
"We are what we repeatedly do. Excellence, therefore, is not an act, but a habit." -- Aristotle
Offline
Old Oct 12, 2006, 08:33 AM   #2
Personal Sales Rating: (6)
Drives: 2010 Genesis Coupe 2.0T
the radio has both a constant +12 and a switched +12. You should be fine tapping into those as long as you aren't pulling too many amps which your ipod module shouldn't. You could also go down a lil more and go to the cigarette lighter if you want to, but that requires removing a few more interior pieces.
You will also fine some nice 10mm bolts you can use for a ground back there as well.
Offline
Old Oct 12, 2006, 08:44 AM   #3
Personal Sales Rating: (7)
Jamdown's Avatar
Drives: 03 GSR -> 06 MR
Use a wiring harness, it makes everything soooo much easier. You can get them at BestBuy/CircuitCity
__________________
Iveytune ftw 336/318
Offline
Old Oct 12, 2006, 10:39 AM   #4
Inprogress's Avatar
Drives: 2006 EVO IX
A wiring harness for a iPod adapter? I've never heard of doing that. How would htat work?
Yeah, can anyone confirm what colors the +12 and switched +12 lines are?
__________________
2006 Evo IX
Offline
Old Oct 12, 2006, 10:42 AM   #5
Personal Sales Rating: (11)
saiyanzzrage's Avatar
Drives: 2006 GG IX MR
Send a message via AIM to saiyanzzrage
Quote:
he meant a harness for the aftermarket radio to the stock connection
Offline
Old Oct 12, 2006, 11:22 AM   #6
Inprogress's Avatar
Drives: 2006 EVO IX
Well yeah I do have that as I have the CDA-9835 currently in the car. it's about to be replaced by the Eclipse CD7000.
Do I tap into the Metra harness? If so, what color wire do I tap for the +12 connection?
__________________
2006 Evo IX
Offline
Old Oct 12, 2006, 03:03 PM   #7
Drives: AS EVO X MR
Red - Switched 12V
Yellow - Battery 12V
Online
Old Oct 12, 2006, 03:57 PM   #8
Inprogress's Avatar
Drives: 2006 EVO IX
Thanks a bunch!
__________________
2006 Evo IX
Offline
Old Oct 12, 2006, 04:21 PM   #9
Inprogress's Avatar
Drives: 2006 EVO IX
Quote:
Originally Posted by mrMTB
Red - Switched 12V
Is that on the factory harnesS? On my metra harness there are only 4 wires, and only illumintaion isn't being used. Should this red and yellow wire be on the factory harness?
And should i just splice into it? I assume i disconnect the batter right?
Thanks.
__________________
2006 Evo IX
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
