Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 1, 2006, 09:23 PM   #1
Personal Sales Rating: (2)
PurEvo's Avatar
Drives: o6 MR
speakers pop when car turns off
My speakers does a pop when the car shuts off. I have an alpine headunit going to a kicker amp powering the jl component speakers (stinger cap). After listening to the stereo, when I turn off the car and everything shuts off, the speakers does a pop sound. I can't figure it out. does anybody know of this problem and can help me fix it? thanks
__________________
06 RR IX MR - Weekend/Play monster - now DD
96 JDM Honda Integra Type R - Daily driver - gone
07 gixxer 1000
Offline
Old Oct 2, 2006, 02:51 PM   #2
Drives: Evo IX MR
Send a message via MSN to M00kiE Send a message via Yahoo to M00kiE
1. check all of your grounding points. make sure you're making good grounds.
2. check to make sure your power wire/remote turn on lead isn't run right next to your RCA. if they are, move them as far apart from each other as possible.
__________________
***MZM - ECUTEK MEGATUNED***
LAN EVO IX MR - 272HP/262TQ
ACT-CUSCO-FORGE-K&N-SUN-SWIFT-TANABE-WALBRO
Offline
Old Oct 2, 2006, 06:07 PM   #3
PurEvo's Avatar
Drives: o6 MR
Well, my power wire and remote wire is on opposite side of the amp from the rca wires so, i guess I should check my ground wires. Can I run my ground wire from the amp to the neg part of my cap? I have my cap neg and amp neg wires going to the same place.
Any ideas?
__________________
07 gixxer 1000
Offline
Old Oct 2, 2006, 06:12 PM   #4
Personal Sales Rating: (3)
deffro's Avatar
Drives: '05 Evo VIII 1965 Chevelle SS
What he was saying is to make sure that the power and remote wires are run on different sides of the car. For example run the rca's down the passenger side and the power down the driver side. I think it is better to have a seperate ground for the amp, however, it will work either way. You need to check your main ground, where the cap is, and make sure that there is no paint or other substance blocking the contact. It sounds like a grounding problem for sure.
__________________
http://www.slowertraffickeepright.com/
Offline
Old Oct 2, 2006, 06:22 PM   #5
Personal Sales Rating: (10)
2Devious's Avatar
Drives: GG 06 Evo IX MR
Check your grounds.
Make sure you are grounded to bare metal.
Your cap and amp should be grounded to different locations. Some caps have distrobution blocks for both power and ground, it is still good practice to ground them seperate.
Offline
Old Oct 2, 2006, 06:25 PM   #6
Personal Sales Rating: (14)
TogueMonster's Avatar
Drives: while receiving head.
Yup yup, sounds like a bad ground. Make sure your ground is good like these guys said and make sure that your wires arent touching, like the RCA's. Ive heard the shut off noises come from two things, cheap amps, which you dont have and bad grounding/wiring.
Offline
Old Oct 2, 2006, 06:28 PM   #7
Personal Sales Rating: (1)
whitey4d's Avatar
Drives: 04 white EVO,93 awd TSi
Yeah make sure theres no power or remote near ur rca cables. They feed over. If ur power and ground are too close together they have a humming sound.
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Old Oct 2, 2006, 08:40 PM   #8
PurEvo's Avatar
Drives: o6 MR
I see what ya'll saying. My power wire is going down the driver side, but my remote wire is running down the passenger side along with the rca's. I'll move the remote wire to the opposite side of the rca's when I have time. My ground might be the problem i guess. I just hooked it up anywhere to get it turned on. I'll go back and redo it to a better ground. thanks. If I have anymore problems, i'll come back.
__________________
07 gixxer 1000
Offline
Old Oct 4, 2006, 04:52 PM   #9
Drives: Evo IX MR
Quote:
Any ideas?
Don't ground the amp directly to the cap! They can ground at the same spot on the car but not on the cap itself.
__________________
Offline
Old Oct 4, 2006, 06:31 PM   #10
Personal Sales Rating: (0)
Drives: evo VIII 2003
If you can't get the turn off pop to go away. You can add a small cap in line with the remot wire. This will keep the amp on longer than the headunit (about a second) Eliminating the pop. Or there is a part mede by stiger to do this as well. Check www.extremeaudio.biz
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
