Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Audio & Security
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 13, 2006, 06:36 PM   #1
Personal Sales Rating: (2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
RS Stereo install... ground wire help.
Ok so I have all of my wires connected and ready to be plugged in on my 06 RS. There is a long ground wire though and none on the new radio harness. Do I need the ground wire or is the car harness already grounded somehow? If so... should I just tape it off?
Offline
Old Sep 13, 2006, 06:38 PM   #2
Personal Sales Rating: (5)
westchester evo's Avatar
Drives: Porsche Twin Turbo...Not stock
ground it to the bar behind the radio,There should be a screw you can take out and put the ground on
__________________
Offline
Old Sep 13, 2006, 06:38 PM   #3
Personal Sales Rating: (13)
rcheung's Avatar
Drives: 2003 Evo 8
Depending on the radio, it may not even work properly if not grounded. What kind of radio do you have that doesn't come with a ground on the harness? I've never seen a radio that didn't have a ground.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
Old Sep 13, 2006, 06:48 PM   #4
it's a pioneer... it's like a cheapy one... I just wanted something to be able to hear some tunes in.
Offline
Old Sep 13, 2006, 06:49 PM   #5
Quote:
yeah I was looking at that... I wasn't sure if the radio would hit it or not when it was in the car. I'll have to try that.
Offline
Old Sep 13, 2006, 09:16 PM   #6
I just read on another thread that the antenna cable grounds the radio.. i'm confused here.
Offline
Old Sep 13, 2006, 09:28 PM   #7
Personal Sales Rating: (3)
deffro's Avatar
Drives: '05 Evo VIII 1965 Chevelle SS
The best thing to do is to go ahead and ground it at a good point behind the stereo. There should be ample choices of where to ground it. Although the stereo MAY work without that ground, it would be safest to do it. I have grounded all of the Pioneers that I have ever installed and they worked well.
__________________
http://www.slowertraffickeepright.com/
Offline
Old Sep 14, 2006, 05:31 AM   #8
Drives: 2000 Honda S2000 , 1992 Nissan Sentra SE-R, 2006 Mitsubishi Lancer Evolution IX SE
The Antenna grounds the radio on the Evo. No other ground should be needed. I just installed a Kenwood head unit last night in my new Evo. I taped off the black ground harness from the headunit harness, and it works perfectly.
Offline
Old Sep 14, 2006, 05:46 AM   #9
Personal Sales Rating: (35)
BADEVO's Avatar
Drives: 2003 EVO
Send a message via AIM to BADEVO Send a message via Yahoo to BADEVO
Um... if you use the factory metal brakets to the metal body of the radio with the metal screws to the metal bracing in the dash.......... see the trend. It's grounded basiclly is what I am saying. The radio should have a ground, the harness might not because the mitsu harness doesnt have a ground in it.
__________________
Quote:
Originally Posted by AlwaysinBoost View Post
the reason is because you can make as many stipulations as you want in order to hold the record. For example I can say I have the quickest/fastest stock turbo 04 WW GSR w/SSL on 93 pump gas & 22psi w/blizzaks driven on a Sunday.
Quote:
Originally Posted by DynoFlash View Post
When you watch a car on the dyno with a Buschur exhuast the velocity of the flow throuh the exhaust is so fast and powerful that the smoke shoots out and back like a rocket
Offline
Old Sep 15, 2006, 05:57 AM   #10
Personal Sales Rating: (10)
2Devious's Avatar
Drives: GG 06 Evo IX MR
In the dash, on either side of the radio, there are 2 screws sticking in towards where the radio goes. Both are covered with a rubber stop. Install a small ring terminal on the end of your ground wire. Remove the grommet/stop from one of the screws. Slip the terminal over the screw. Screw the grommet back on so that it is holding the terminal tight against the metal dash casing.
Wa-la the head unit is now grounded. This is how I grounded both my head-unit and my touchscreen monitor.
Offline
Old Sep 15, 2006, 02:20 PM   #11
thanks all... I got it now though.
Offline
Old Sep 26, 2006, 11:50 AM   #12
Personal Sales Rating: (0)
1evilevoRS's Avatar
Drives: 2006 evolution RS, 1971 el camino SS
where did you get the pigtail for the stock harness?i cant find it anywhere
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
