Low oil pressure @ idle
Ok did a rebuild on the bottom end new crank acr race bearings, manley rods, ross pistons 9.0:1 compression. New oil pump and complete gasket kit and ams bal. shaft delete kit (race).
primed oil and fuel..no problems...car started easy as pie 3 cranks. Ran for a couple of minutes then the oil light came on..turn it off check oil...low from it filling the system. added oil back to full. started fine ran for a couple of min again then oil light on again. checked oil and its full. check for leaks...none bone dry. start again..idle oil light on...give a little gas goes off at 1300rpm..checked that twice then shut it off..checked for leaks again..bone dry..do not want to start again until I can figure it out. any ideas would be appricated. Oh the oil pressure sender in block is new as well.
__________________
The measure of a good car is how well it reacts in all road situations, NOT just how fast it goes straight.
