Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 26, 2009, 07:35 PM   #1
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Modifying your MIVEC cam gear
DISCLAIMER: Do not do this unless you understand how to set your cams up, clay the motor, and properly implement this in whatever ECU you are using. If you are unable to do any of these things please leave this to professionals. I make no guarantees, warranties, either expressed or implied, campaign promises, baby kissing, etc. There is always potential for failure even when everything is "planned out" so please keep this mind.
Tech:
Pretty simple actually, you have your MIVEC cam gear here:
You undo the inverted torx (they're not tight) with hopefully the right tool. Or if you are like me a 1/4 6pt got it done in a pinch.
It then looks like this:
The rotor has apex seals which will most likely stay in the housing (see the first 2 pix and you'd see them in the housing) and that fine. It looks like this stock:
Grind it down a touch. The easiest way is to make sure that you take a little at a time and test fit. You end up taking it down to just about the dash between the 1-2.
Thoroughly clean it one last time, install the apex seals (they'll chill but you can knock the springs out if you're not careful), and then reinsert in the housing:
You have successfully added 6* of motion. Degree everything to make sure you installed it correctly, and remember doublechecking is your friend. Its simple to do the math when you know what direction you want to go to make it all line up. There are a few ways to go about it, but the easiest is to go off a tooth and then over advance the cam in your MIVEC map to keep it even (remembering you are tring to achieve 3.5* or so to compensate for the 6mm deck height increase). I am not going to say one way is right or not, nor how I am doing it. If you cant figure it out on your own this is something you do not want to be doing in the first place (reread disclaimer).
Notice the edge of the housing has a lip though. The only way to remove that is is with a table mill. Once that is gone you will open up about another 8*-10* of motion (for a total of 44-46). I have no idea why you might want that much but it is there. You can all thank Grocmax for the math on that one (also dont argue with him, when he says something he isnt guessing).
The reason I did this was to add back the full range of motion since I used a tall deck block with my 2.2l. On the exhaust side I added a cam gear as is common practice but on the MIVEC side I needed to be inventive.
aaron
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
My car- 574whp@29psi stock block, pumpgas, ETS and FP3586...for now.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds in stock, $1000 with ETS Magnus pipe, dual rail available also.
Proud retailer of GSC cams
FIC Master distributor
OmniPower USA Dealer
Offline
Old Oct 26, 2009, 07:44 PM   #2
Personal Sales Rating: (40)
wshihdnevo's Avatar
Drives: '05 apex silver evo 8
Send a message via AIM to wshihdnevo
Awesomeness abounds!!!
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Offline
Old Oct 26, 2009, 08:30 PM   #3
Personal Sales Rating: (1)
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
That's really awesome Aaron
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Oct 26, 2009, 09:46 PM   #4
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
There is no need to try to rebalance the lobe piece after grinding off some of the limiter?
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Old Oct 26, 2009, 11:41 PM   #5
Personal Sales Rating: (7)
fostytou's Avatar
Drives: Graphite Grey IX SE (88590015), '04 FZ1, Former: 35R Powered Eclipse GST, 6/4 TSi AWD, Bandit 600s
Send a message via AIM to fostytou
You guys are just as awesome as you are insane
__________________
Corn Fed 365hp/360tq
  • AMS FMIC, AMS LICP+UICP, AMS Front lower motor mount, Megan O2, Megan DP, Perrin HFC, Fujitsubo RM01A Cat-back, Walbro 255, RC 1200cc Injectors, GSC S1 Cams, Ghetto 3" intake +AMSoil EA Filter
  • Tephra V6, JDM MAP, Direct boost ctl w/ AEM solenoid, AMS Tuned
  • Pioneer DEH-P9790BT, 40GB iPod, 10W6V2, Alpine PDX-1.1000, Passport 8500 x50 Hardwired, AEM Tru-Boost (Guage only), Auto-dimming mirror, 35% Tint
Offline
Old Oct 26, 2009, 11:58 PM   #6
Silver Sponsor
Personal Sales Rating: (8)
Lucas English's Avatar
Drives: '04 EVO SSL
Quote:
Looking at it when it was apart its not balanced in anyway we could see. The whole thing is pretty light, the hub isnt a balanced piece that we could see either. The "rotor" is really unbalanced it looks like when left stock.
__________________
ETS powered 766whp '04 EVO GSC S2 cams , AEM,E85,Magnus Cast
Mods for 2008 (Still pushing the stock turbo)
http://forums.evolutionm.net/drag-racing/365817-getting-closer-10-882-125-stock-ix-turbo.html
www.EnglishRacing.net sales@englishracing.net
www.Extremeturbosystems.com for all your Turbo and IC needs.
English Racing 360-210-7484
MAGNUS Motorsport Cast Manifolds in stock (PM for sales), special pricing on dual rail manifolds.
Offline
Old Oct 27, 2009, 09:58 AM   #7
Silver Sponsor
Well I dont know how awesome I am, maybe insane I will agree with I might mess around with more advance later, but for now I am just looking to get things as close back to stock ranges as possible.
__________________
Offline
Old Oct 27, 2009, 10:23 AM   #8
Personal Sales Rating: (0)
im4u2nv's Avatar
Drives: ix se
Great find-
__________________
Luv my TB ix SE
English Racing Crew FTW!
JR/ETS, Midgetspec, POS
Offline
Old Oct 27, 2009, 08:19 PM   #9
rolly1818's Avatar
Drives: 2006 JDM Evo IX
awesome stuff, i dont think i got the balls to try it though. would be cool to see the effects of this on the dyno.
think the stock cams can make a little more?
Offline
Old Oct 27, 2009, 08:28 PM   #10
Drives: evo 9 gsr,2008 vw jetta gli
suscribe for results
Offline
Old Nov 3, 2009, 03:17 PM   #11
Personal Sales Rating: (15)
Evo_Kid's Avatar
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
subscribed
Offline
Old Nov 5, 2009, 01:28 PM   #12
Chef-j's Avatar
Drives: N/A
Quote:
Originally Posted by rolly1818 View Post
awesome stuff, i dont think i got the balls to try it though. Would be cool to see the effects of this on the dyno.
Think the stock cams can make a little more?
+1
Online
Old Nov 12, 2009, 09:20 PM   #13
MajorGunHo's Avatar
Drives: 2006 Evo IX MR
Eventually, I'll be techie enough and equipment savy enough to do this, until then, well done! Now just need to find a friend capable of it
__________________
06 Evo IX
04 Evo VIII
05 F350 Diesel Puller.
Offline
Old Nov 12, 2009, 09:43 PM   #14
mynx87's Avatar
Drives: 06 GG evo 9se
Very nice write up
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
