Oct 26, 2009, 03:01 AM
Personal Sales Rating: ( 0)
Drives: lancer
oil pressure drop-what is dangerous??
Oil pressure drop-when to act??
Hi,
My oil pressure in my IX is dropping from 100psi down the straight to 30 -40psi around a long fast right hander. From what I have read this is common with evo's.
It idles at 20psi.
Is 30 -40 psi enough pressure - at what pressure drop do you do something about it?
Any engine builders/track guys with some advice??
Also, anyone logged oil pressure after fitting the AMS sump or an accusump?
Thanks in advance.
Offline
Oct 26, 2009, 03:36 AM
Personal Sales Rating: ( 4)
Drives: 1987 RX-7 sold, 1993 RX-7 sold, 1996 cobra sold, 1999 F350 sold, 2006 Evilution IX
Quote:
Hi,
It idles at 20psi.
Thanks in advance.
As long as its hitting 20psi when idle your fine. The oil pressure will go down when you let off the gas
__________________
Tuned by the Criddler
Spark Tech
Online
Oct 26, 2009, 06:44 AM
Personal Sales Rating: ( 20)
Drives: AMS Equipped EVO VIII
If you do not have 10psi for every 1000 rpm I would do something about it, you don't want to take any chances. Sounds like you are a prime candidate for the AMS wet sump oil pan and pickup.
__________________
EVO VIII
Offline
Oct 26, 2009, 04:08 PM
Drives: lancer
Thanks for the reply. Yes, have emailed AMS and an agent but no response.
I take it you have the AMS sump? How was the fit .....and the oil pressure variations around a track?
Offline
Oct 26, 2009, 04:15 PM
I can't speak for this part because I don't own it. I am a loyal AMS customer because they build great products that fit in all of my other experiences. It sounds like you have the need for it being why I recommend it, but I am sure they will get back to you as soon as possible with their recommendation as well. Good luck, if you do decide to purchase it let us know your satisfaction on fit, finish and operation.
__________________
EVO VIII
Offline
Tags
3040, 87, drive, drop, drops, evo, mazda, oil, pickup, pressure, psi, put, rx7  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
