Oct 6, 2009, 11:04 AM
Personal Sales Rating: ( 0)
Drives: Lancer Evolution IX
boost 'flutter'
Weird problem with my 9:
at full throttle the boost does a ... 'flutter' for lack of a better term. It'll be steady until about 10psi, then start wavering and by the time its at peak the needle on the gauge is going between 25 and 20 or so. (its the most extreme at peak boost, lower than that it fluctuates between about 2psi then grows as the boost grows).
I've had my guy check it multiple times, boost leak test, checked all lines, even replaced the throttle body, but the problem still persists.
I'm beginning to think it might just be with the gauge itself because I do not FEEL a loss of power or boost in the car, it only seems to appear on the gauge.
Thoughts?
Offline
Oct 13, 2009, 05:12 AM
Personal Sales Rating: ( 10)
2003 Mitsubishi Lancer Evolution
Drives: 03 Banana EVO VIII
change the gauge or check you BOV
__________________
You have never lived life, until you have choked someone out!
PS3 ID: Kinikuchunks, Add ME for some Street fighter 4 and Killzone 2 action!
KUNiiiZZZEEE Dial-IN
Offline
Oct 13, 2009, 08:48 AM
changed out the BOV completely with another one that we knew for sure worked, so it's not that.
The gauge is the next thing to swap out, just need to buy a new one first
Offline
Oct 13, 2009, 08:49 AM
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
what boost controller?
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Oct 13, 2009, 08:50 AM
Not positive, it's ECU controlled though
Offline
Oct 13, 2009, 09:19 AM
Silver Sponsor
depending on how its set up, the boost correction could be causing your duty cycles to be going up and down and making it fluctuate.
cb
__________________
www.ChadBlock.com
Offline
Oct 13, 2009, 09:22 AM
Quote:
cb
those are a lot of words put together that i know nothing about
but I'll definitely look into it, i really appreciate the feed back!
My car will be at the shop today so i'll ask about it.
Offline
Oct 14, 2009, 09:27 PM
So I got my car back from the shop, got new cams springs and retainers a aquamist meth kit and a tune and now it doesn't do the flutter anymore...sooo... yay!
Offline
Oct 14, 2009, 09:44 PM
Personal Sales Rating: ( 1)
Drives: EVO IX SE
What you put down on the dyno?
Offline
Oct 15, 2009, 08:39 AM
Don't know numbers yet, all I know is it's fast as ****!!
Offline
Oct 16, 2009, 10:38 PM
Drives: evo x
hmm odd, i would have guessed the wastegate might have been fluttering
Offline
Oct 16, 2009, 11:16 PM
I don't know what a wastegate flutter would have done, but like I said in the original post, I didnt feel any loss in power or that it was lagging in anyway :/
but its all good now so I don't have anything to worry about...yet haha
Offline
Oct 18, 2009, 06:19 AM
Personal Sales Rating: ( 11)
Drives: WW IX MR, RR 2001 EVO 7 RS-2, 90 gsx (sold) 98 gst (sold) 91 talon awd (RIP)
cb
totally agree ^, i had my blitz dsbc elec boost controller set wrong the duty cycles were off and war doing exactly what u are describing, played with the settings and probally the best boost cont i ever used !!!!
__________________
365hp/358tq IVEY TUNED = bolt on's stock turbo,stock cams, on 93 and out of fuel, no meth, <~ old setup
SHEPTRANS.COM
new setup / HTA 35r turbo kit, buschur stage 3 motor, buschur stage 3 head, jun mivec cams, 1,200cc inj, buschur ported intake mani, buschur 65mm t-body, buschur race fmic, buschur double pumper,buschur 3in turbo back, buschur/DEI turbo heat blanket.. eng mang : hks vpro with knock amp/ivey tune !
new numbers soon !
Offline
Oct 18, 2009, 07:20 AM
Drives: 06 Evolution 9 GSR
im assuming your boost controller is a three port in which the stock ecu controls. If you are tuned that shouldnt be an issue. You can rule out the bov since you said you changed to one that works. My guess, and its only a guess, is since you are not feeling any power loss, but your gauge is being retarded, change the boost gauge then. What kind of gauge are you using right now? Also to, can you hear any fluttering when you are on boost. IE the turbo making weird noises when you are wot. There could be many factors to causing this issue. What sucks is you are going to have to use the elimination process. But def change out your gauge and see if that works.
__________________
SSG
U.S ARMY
"SAPPERS"
Online
Oct 18, 2009, 09:20 AM
i appreciate all the feed back guys. If the problem did persist, I would have changed out the gauge cause it's a cheap-o Autometer boost gauge. But as I said in post 8, I got a re-tune with the addition of some new parts and now it doesn't flutter at all anymore. So i guess it must have been the boost controller.
Offline
Tags
body, boost, evo, flutter, flutters, gauge, leak, peak, steady, throttle, turbo, wavering  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
