Oct 3, 2009, 11:23 AM
Personal Sales Rating: ( 0)
Drives: 01' Evo VII
Burning water. What to do?
Car's a Lancer Evo VII I've had for 3 months. Ran great till last week. So great that never checked some itens due to the low - and granted - mileage of just 26.000mi.
Last week the cyl 3 started to fail. Yesterday I took plugs off and the 3rd was completely covered of water. Compression was 130/130/30/30, so there a problem for sure. Engine was fully built with ARP bolts by the previous owner, so the shop might have done something wrong.
Took head cover off and found some little white spots here and there, like sand. In fact, looked like small water drips. You can see and clean them, but not fell by touch. No rust signs.
The "tuner" installed NGK BKR9EIX plugs, and that explain the completely fouled pistons tops. Funny this all happened just after I bought some BPR8ES.
I'd like to share what I want to do and hear some opinions:
1- Drain oil to check the extent of fluids mixing;
2- Pull head;
3- Pull rods/pistons to check bore clearance and match pistons to cyls;
4- Take rings out to check clearance. Match rings to best cyl for each one;
5- Check rod bearing for damage and clearances and replace if needed;
6- Take main cap out to check for bearing damages, and replace as needed;
7- Replace rod and main bolts by ARP studs/bolts;
8- Replace head ARP bolts for standard ARP studs;
9- Replace every gasket and seal;
Great chances I'll send the head for a complete tear down. Just basic stuff: gasket matching, polishing, new bronze valve guides, new valve seals and throw in GSC S1 cams.
Is there something else I need to check? As I told, I've had the car for just 3 months so I'm new to 4G63s.
Thanks in advance for any help.
Offline
Oct 4, 2009, 07:59 PM
Drives: 99' Galant ES
sounds like a headgasket problem. could have failed to re-torque the head studs after the motor was heat cycled and it lifted on those two cylinders, thats a small chance, but still a chance. The only way your getting water (coolant) into a cylinder is from a bad headgasket or a damaged coolant passage in the head or block. Try and do a leakdown test and see if your getting air into the coolant system, just leave your radiator cap off and do the test if its a headgasket or damaged passage the coolant in the radiator will start bubbling like crazy.
__________________
Its all fun and games til the cops show up!
Offline
Oct 16, 2009, 10:53 PM
Drives: evo x
I wouldn't really go through that much work. Just yank the head, make sure block and head arent warped, and install a new headgasket...
Offline
Oct 23, 2009, 02:10 AM
Drives: Built 2006 EVO MR
2- Pull head;
bro do a leak down test and see where its leaking from and then fix it, take it to a pro for sho
Offline
Oct 24, 2009, 04:59 PM
Personal Sales Rating: ( 1)
Drives: Evo VII , Ferrari modena , jeep srt8, CR 250
re torque headgasket
if this doesnt work try a new headgasket
and if this doesnt work either take your head off and a close check!
i think a new rebuild engine should have 180 , 180 , 180 , 180 of compression, correct me guys if im wrong?
good luck
__________________
Mods:
Motec M800
Cusco coilovers
Complete roll over racing cage
HKS Intercooler
Forged JE piston
Forged H -Beam Manley Rods
OZ rally Rims
ARP headstuds
Exedy Twin Carbon Clutch
Green Turbo
Offline
Oct 25, 2009, 06:32 PM
Drives: 01' Evo VII
Already took the head off. All the cylinders are shiny, not a sign of the previous honing, wich is bad. The 3rd cyl - the one that was leaking - has a damage on the wall that I can feel just by touching. As the engine was already bored to 85,5mm, now I need to check if it's possible to bore up to 86mm.
Will post pic later.
__________________
01' Lancer Evolution VII
Offline
Oct 25, 2009, 06:42 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
No one should ever use 9EIX plugs. The car would be lucky to run 20 miles without misfiring with those.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Oct 25, 2009, 09:53 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
Been running sets of those fine for over 20,000 miles...
- Bryan
Offline
Oct 25, 2009, 10:00 PM
Silver Sponsor +1
Back in 2006 when we were running 10's in our 2005 MR we tested all the plugs available at the time in about 3 heat ranges each, HKS Dli, MSD CDI, COP ignitions, Okada coils etc and the 9EIX was the worst plug out of all of them.
Any ethanol powered car running 9 series NGK plugs is pretty funny.  The fuel is colder as it is and running a colder plug on a colder burning fuel is hampering performance and ignition. We have the track results and testing to actually back up our claims.
There would need to be a real good reason to ever think about going colder than an 8 series plug.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Oct 26, 2009, 12:38 AM
Silver Sponsor
Drives: EVO, STI
I ran E85 for over a year before you even found it better than Methanol you used to think was god, and before you tried to make believe your car was still running a stock motor.
I've personally run 9's for over 20,000 miles, just a tad bit more than the 20 miles you claim before fouling. Don't worry your secret is not safe with me.
- Bryan
Offline
Oct 26, 2009, 05:50 AM
Drives: 01' Evo VII
Pics
Hereīs the worst score I could find. There are some scratches in all the 4 cyls, just as if a grain or two of sand got stuck over a ring.
__________________
Offline
Oct 26, 2009, 06:04 AM
Silver Sponsor +1
- Bryan
Ethanol is not better than methanol FYI. God is spelled with a capital G. FYI. One of my cars, the gray MR specifically has been on stock motor for the last two years.
NGK 9EIX are still the worst plug for the Evo in the end as they are too cold for the car.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Oct 27, 2009, 12:10 PM
you can machine your block to 86mm , no problem at all.. but thats the las t super for you block!
__________________
Mods:
Motec M800
Cusco coilovers
HKS Intercooler
Forged JE piston
OZ rally Rims
ARP headstuds
Green Turbo
Offline
Nov 3, 2009, 03:41 PM
how about NGK 8īs copper head ???
__________________
Mods:
Motec M800
Cusco coilovers
HKS Intercooler
Forged JE piston
OZ rally Rims
ARP headstuds
Green Turbo
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
