Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 27, 2009, 05:27 PM   #1
Personal Sales Rating: (0)
tolga900's Avatar
Drives: EVOLUTION IX GSR
Send a message via MSN to tolga900
oil light check help
Nearly 2 months i have problem when i used my car 10 minutes later in 800-900 rpm car oil light is lighting.oil lever is fine and i use defi oil gauge and it shows 1,8 and 1.9 bar in 800-900 rpm what can be the problem i use castrol edge 10-60 how can i solve this problem? also i have a noise in the head i change 16 lifters but noise cant stop.
Offline
Old Sep 27, 2009, 05:39 PM   #2
Personal Sales Rating: (1)
hotdog's Avatar
Drives: 2008 Evo X
Change the oil gauge sensor. It's like a 10 dollar part, and they die constantly.
__________________
2008 Evo X GSR. Rally Red.
Buschur
UICP/LICP
Buschur Intake/MAF Pipe/Shield
Buschur Cat Back Bullet
Buschur Test Pipe
Buschur Shifter Bushings
Buschur Evo X FMIC
Online
Old Sep 28, 2009, 09:59 AM   #3
tolga900's Avatar
i change sensor problem continue anyone help
Offline
Old Sep 28, 2009, 11:52 AM   #4
Drives: JDM evo VIII GT35
humm very interesting,
first try to chande to grade of oil to 15w50
if problem still here:
does your car use oil ?
did you install cam ?
did you bleed your new lifter ?
do you use balancer shaft removal kit ?
let me know
Offline
Old Sep 28, 2009, 01:09 PM   #5
tolga900's Avatar
i use 10-60 i use cosworth 272 cams and brain crower springs and retainers no removal kit and dont bleed lifters
today i made a compession test ,on cylinder 3 and 4
comp ratio is 1bar lower then the 1 and 2 which are identical..i ask my friend about the sound coming from the head,he suspects exhaust side valves on 3 and 4 cyl..what can you tell about this ??
Offline
Old Oct 5, 2009, 12:04 PM   #6
did you find the problem ?
is it because of your low comp rotio ?
Offline
Old Oct 5, 2009, 12:33 PM   #7
Personal Sales Rating: (14)
2005 Mitsubishi Lancer Evolution
stryderlis's Avatar
Drives: TB Evo 2005
Does the oil light come on and off around 800-900 rpm? Mines used to flicker on and of during idle and it was the oil sensor. I see you changed your oil sensor so I'm not sure what your problem is.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
