Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 27, 2009, 02:28 PM   #1
Personal Sales Rating: (4)
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
Weak spark - any test for coils?
Ill give the main details.
62,500 miles on car - presumed stock coils
11.3 AFR during pull
NEW BPR8es plugs - gapped at .023
New OEM wires
7800 RPM redline
93 octane only - no meth.
If I run 18psi. No breaking up at all. Pulls hard to redline.
If I run 20psi - a few blips on the pull usually around 6500+ --Blips start after passing 18psi
If I run 22 psi - it sputters and barely pulls though the rpms. - chaos starts after passing 20psi
I figure it has GOT to be weak coils. It sounds like its only one coil tho -- as it its a complete brick wall -- just pops and bucks like crazy.
Is there a test for the coils? Aside from switching or swapping coils with someone else? I could have sworn that with my setup.. stock coils should have nooo problem lighting .. I just cant figure it out.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
FP 80mm Red, BR Race FMIC, BR 65mm TB, MAP Intake mani, BR 3" Exhaust, Megan O2, MAP Exhaust mani, Kelford 272's, Supertech Springs, Spoolin COP, HKS intake, HKS BOV, ECU controlled boost, Innovate WB, Defi Guages, Exedy Twin HD, ShepTrans and Xcase.
Sponsored by the USMC and US Army.
ROM - 96530006
Tuned by Asmodeus
Offline
Old Sep 27, 2009, 02:30 PM   #2
Personal Sales Rating: (15)
06MREvo's Avatar
Drives: 97GSX<GGIXMR
Send a message via AIM to 06MREvo
You have any evo buddies near by that you could swap their coils on your car and see what happens? Thats a pretty easy test...
ha nvm just read your last sentence...sh*t sorry...haha...
__________________
12.05 @ 116.5mph....93 oct., Stock turbo, Stock motor (Stock cams), Stock Intake Manifold & TB, crappy 6 spd tranny, a bunch of bolt-ons, SPARKTECH nonCDi COP, 25 psi, Tuned by Kasey @ MAP (2009)
For the Fastest/Quickest Stock Appearing Turbo Times of 2009 Click Below
For all your Ignition NEEDS & WANTS, CLICK BELOW!!
Offline
Old Sep 27, 2009, 02:44 PM   #3
xRoguex's Avatar
=) i know that will work. i just need to meet up with some one.. I was just curious if there was some way to test them via volt meter?
What actually causes them to become weak?
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Sep 27, 2009, 02:49 PM   #4
06MREvo's Avatar
Old age...weather the car is driven in could have something to do with them dying on you earlier then other evo owners...I see your running a Red...depending on the boost and power you are putting down, maybe with almost 63k miles they just can't cut it anymore...PM Craig @ Sparktech about his non cdi COP setup...I am running it on my stock turbo car and I love it...pulls MUCH better till redline...
__________________
Offline
Old Sep 27, 2009, 02:55 PM   #5
xRoguex's Avatar
Ill pass on sparktech. If I buy any non-cdi - it will be spoolin's setup. Same product - half the cost.
At 22 psi - i would bet I am at or around 300whp. Stock coils should do that in their sleep.
My setup is ready for more-- but with it not lighting.. its pointless to turn the boost up.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Sep 29, 2009, 03:43 PM   #6
xRoguex's Avatar
No one?
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Sep 29, 2009, 03:45 PM   #7
Personal Sales Rating: (5)
Gamble's Avatar
Drives: what's a car?
Try .026 gap.
Offline
Old Sep 29, 2009, 04:06 PM   #8
xRoguex's Avatar
Quote:
Originally Posted by Gamble View Post
Try .026 gap.
How would.. further apart.. help...?
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Sep 29, 2009, 08:27 PM   #9
Gamble's Avatar
Try it.
Offline
Old Sep 29, 2009, 09:04 PM   #10
Personal Sales Rating: (0)
I have been having misfire issues and I swapped my cam sensor and it went away. I would try that. Turbotrix also stated that on a stock ecu a bad cas will cause misfires.
Good luck.
Offline
Old Sep 29, 2009, 09:47 PM   #11
xRoguex's Avatar
well - it only happens at high boost.
Tomorrow i have another 8 comming over.. we will be swapping parts all day. I will start with the .026 gap.
Worth a shot.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Oct 2, 2009, 01:03 AM   #12
Gamble's Avatar
Update?
Offline
Old Oct 2, 2009, 12:42 PM   #13
xRoguex's Avatar
you bet. Coils are weak. Plain and simple. I drove it with my coils in it at 20 and then again with 22 psi to confirm the studder.
I then replaced them with a set of coils out of an 03 evo with the same miles on it. BAM - 22 psi was strong til redline.
Did not change plugs, or wires. Just simply swapped out both coils, and it idled, started, ran and cruised smoother.
Figures.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Oct 2, 2009, 12:50 PM   #14
Personal Sales Rating: (19)
warp9's Avatar
Drives: AWD Machines
No need for that cold of a plug with your setup, especially in the colder air. That might be the cause as well. Go to the 7es gapped at .24
__________________
2004 Evo RS Street Car
FP Red/Stock Motor/Stock ECU
11.03 @ 123
11.34 @ 121 (93 Oct.)
WARP9 Tuned
Offline
Old Oct 2, 2009, 12:52 PM   #15
xRoguex's Avatar
Quote:
Will not light.
I have 8es's gapped at 22 and it wont fire - with my coils.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Tags
20, 20psi, car, cdi, cop, ecu, evo, past, psi, spark, spoolin, sputters, studders, symptoms, testing, unit, weak
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
