Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 23, 2009, 05:42 AM   #1
Personal Sales Rating: (1)
Drives: 03 TB Evo VIII, 89 Buick Century
Cuts out at only at WOT
Ive been searching and searching to find a solution, but I havent found anyone that had the exact same issue yet.
The car runs great, doesnt miss a beat until you go WOT. As soon as it builds 10psi the car cuts (not sure if its fuel or boost). It car build more than 10psi of boost part throttle without breaking up and cutting out.
I did gap and replace the spark plugs. I did check all my clamp to make sure they were tight. I replaced the wastegate lines.
Im not sure what it is...I wondering if anyone can shed some light on this issue. I feel like I might be missing something obvious here
Online
Old Sep 23, 2009, 05:59 AM   #2
Personal Sales Rating: (15)
kanyonkid's Avatar
Drives: evo8MR + subi RS +08 Lancer
lower ur spark plug gap... wat is it at now? i wouldnt go lower than .022 if ur already that low. other than that i cant think of anything else it could be really, assuming ur tuned by a pro
__________________
Lots o' bolt on's... suspension, brakes, motor
327awhp/304awtq est. DLL @ roughly 23psi
New time:
12.13@113_____stock block, head, turbo... 6speed
Offline
Old Sep 23, 2009, 06:14 AM   #3
Quote:
Thanks for the reply,
I have them gapped at .027 I will definately start by gapping them down. I would hate to go to the dyno tomm. like this, but maybe its something a tune could fix.
Online
Old Sep 23, 2009, 06:39 AM   #4
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
Did you boost leak test the car?
Do you have a Wideband in the car? If so what does it show at WOT?
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Online
Old Sep 23, 2009, 06:48 AM   #5
Personal Sales Rating: (9)
CAD EVO's Avatar
Drives: 05 GSR & K8 GSX-R600
Send a message via AIM to CAD EVO
Is the car sputtering when you reach this threshold??? I had a similiar situation and I ended up replacing my ignition coils & wires with a newer set and it did the trick.
Offline
Old Sep 23, 2009, 06:57 AM   #6
I do have a wideband, but it cuts out so quickly its hard to say what the A/F is.
I did not boost leak test the car yet, b/c I figured if I can build 17psi at 3/4 throttle, then Im not bleeding off boost. Then again I could be wrong...
Online
Old Sep 23, 2009, 07:01 AM   #7
Quote:
This feels like fuel/boost cut. Did yours only do it @ WOT? This is the only time it does. Its not sputtering or missing, it simply just cut all power.
Car's mods are TBE and intake. The car was "street tuned" by the previous owner, so Im unsure of the quality of tune I have a date tomm. to have it dyno tuned, Id just hate to show up like this...
Online
Old Sep 23, 2009, 08:09 AM   #8
Tried gapping the plugs down to .024-025 and nothing changed. Its definately some kind of fuel/boost cut thats happening ONLY @ WOT.
Online
Old Sep 23, 2009, 08:10 AM   #9
2004 Mitsubishi Lancer Evolution
binky's Avatar
Drives: FP Black Powered 2004 Mitsubishi Evolution VIII SSL
Send a message via AIM to binky
Your hitting boost cut. Up the boost cut in your ROM with ecuflash and you should be all set.
-Bink
__________________
New Setup: FP Black
Original Setup:
341 WHP @ 5948
341 WTQ @ 4698
VDR 5.6 - EvoM mode
Stock VIII Turbo @ 27 PSI
12.81 @ 107.7
Offline
Old Sep 23, 2009, 09:10 AM   #10
Personal Sales Rating: (0)
Brsox10288's Avatar
Drives: 2006 Evo SE-SSL, 2001 Eclipse, 05 Mustang GT
I had this happen before, did you put new stock plugs back in?
Offline
Old Sep 23, 2009, 09:16 AM   #11
Quote:
Originally Posted by brsox10288 View Post
i had this happen before, did you put new stock plugs back in?
ngk bpr7es
Online
Old Sep 23, 2009, 09:35 AM   #12
Personal Sales Rating: (27)
tweakdsm's Avatar
Drives: 05 WW EVO RS
Send a message via AIM to tweakdsm
what mods? car was running fine before?
check your MBC, do a boost leak.
__________________
05 RS....Powered by Big Turbo, 2.0 build in progress /// APM RACiNG
Offline
Old Sep 23, 2009, 01:12 PM   #13
Personal Sales Rating: (7)
shivaswrath's Avatar
Drives: a stock EVO, a rarity amongst all
Send a message via AIM to shivaswrath
how many miles on your ignition coils & wires? Might explain why it's breaking up under WOT. . .or maybe your local gas station isn't giving you "true" 93? Could retard timing because of that. . .
__________________
Driving an unconventionally fast car with unconventionally functional styling. . .
"Sleeper Tarmac Black". IVEY tuned September 2007:325awhp/345awtq-Dynojet
"If you haven't driven an Evo, it's hard to explain why this car evokes feelings of utter lust; the driving experience is simply that pure" Road and Track, Feb 2005 Long term test
Offline
Old Sep 24, 2009, 09:08 AM   #14
Quote:
The car is not breaking up. It's not ignition related bc it simply cuts.
It does not spit, sputter, misfire, ect...When I go WOT and it build about 10psi, it hits a brick wall.
I already put different gas in from another gas station. Still the same thing.
Im taking the car to Shane @ DB Tuning this afternoon, hopefully we can sort it out. Ill report back then.
Online
Old Sep 25, 2009, 05:47 AM   #15
Well I figured it out...the NO LIFT to SHIFT was engaging when I would go WOT. I had recently adjusted my clutch so it must of messed with how it was set. Car works perfect and made 242whp & 232tq on 22psi on a Dynamic Dynameter.
Online
Tags
10psi, 95, close, cuts, cutting, eclipse, engine, evo, mustang, plugs, spark, sputters, wot
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
