Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 19, 2009, 06:50 AM   #1
Personal Sales Rating: (9)
nirvevo's Avatar
Cam and Springs question
OK, given an equal rev limit (say 7800 rpm), would the stock valve springs actually have a higher load and at least as fast of a recovery rate with a 272 cam as it does with the smaller stock cam, since it is not traveling as far as it does with a smaller cam?
It seems that the spring tension would actually increase with a larger cam, all else being equal.
__________________
"happiness is a warm 4g63"
"my dyno is a quarter-mile long"
And my absolute FAVORITE!
please shorten your signature there is no need for it to be 20+ lines long
thanks,
evom staff "
FINE...
03 VIII FP Red(80mm inlet & Oil Line)RMR3"TB&DPInvidia O2BuschurP&CStockExManiBuschurTwinPumpRC1200ccAeromotiveFuelRailNiseiICInjenIC&Intake
MilSpecTB&PIForgeBOVHallmanBCw/remote272KelfordsFPBeehiveSpringsExedyTwinTXSTuner Pro&WidebandE-85TobzTuned
Offline
Old Oct 14, 2009, 10:59 PM   #2
Personal Sales Rating: (0)
Drives: Evo 8 GSR
In short the 272's are punishing the stock springs more than the factory 248's. If you're only playing with the 7k redline your safe. That's what the springs can handle without failure.
Offline
Old Oct 15, 2009, 10:21 AM   #3
Silver Sponsor
Personal Sales Rating: (80)
MitsuJoe's Avatar
Drives: 03 BBY EVO by PPI and 00 Civic SI
Send a message via AIM to MitsuJoe Send a message via MSN to MitsuJoe Send a message via Yahoo to MitsuJoe
Which 272 cam?
__________________
Paradigm Performance Innovation
http://www.paradigmperformance.net
Michigan's EVO Club @ www.miEVO.net
Offline
Old Oct 28, 2009, 09:49 PM   #4
Drives: 05 VIII
mmm... interested
Offline
Old Oct 29, 2009, 06:48 AM   #5
nirvevo's Avatar
I have since learned a a little about spring rates and bind specs etc... not a lot, but enought to know it's necessary to match your cam lifts and duration to the appropriately spec'd spring.
I know that some guys have kept their OEM Evo valve springs when they put Kelfor 272's in, but most are restricting their rev's to 7800. (as will I)
One thread talked about the springs showing a drop in clamping after use. I wonder how much of a drop off in spring performance various brands have?
I am going with FP Beehives for a few reasons.
1. Double springs put a heavier load on other valve train components, my build doesn't require them so why do that.
2. The argument about beehive design is a worthy consideration.
3. Titanium retainers are more brittle that the OEM's - longevity issue - I won't be dealing with that issue this way.
4. I like FP's R&D and recommendations. in general.
5. Valve springs are not forever, I will likely revisit the issue when a rebuild becomes necessary. I hope to be done for a while after this. (famous last words)
__________________
thanks,
evom staff "
FINE...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
