Sep 7, 2009, 12:44 AM
Personal Sales Rating: ( 0)
Drives: e46 330ci and Evo 8
no boost pressure?
Hi guys, im new to the evo and just started work on it. There seems to be a problem with boost as the boost gauge is showing no boost pressure, we checked all the wiring and everything seemed to be fine, then we checked the mbc and there is no boost pressure in the line before or after the mbc. We are thinking it is the wastegate and its stuck open, i read on here that it could be the wastegate selnoid (sp) which causes the wastegate to remain open.
We took the car out for a spin and everything seems to work fine and it runs strong but no boost pressure from the wastegate out....
any ideas what it could be?? Thanks
__________________
Annnnnnnnnnnddd the boost kicks in
Offline
Sep 7, 2009, 07:09 PM
runs fine with no boost? or is the guage not reading?
it is reading vaccum still right?
Offline
Sep 8, 2009, 04:20 PM
no the turbo is working, but we are not getting a reading to the boost gauge or any pressure to the mbc
__________________
Offline
Sep 9, 2009, 11:09 AM
Drives: 04 RS
what line do you have your boost gauge tapped into? And as mentioned above does it still read vaccum
__________________
FP RED, Map ex 02 dump, 3inch cb,Exedy twin, ETS 3 in., FIC 750s, Arp's, injen piping, Megan Mani, BC 272s, Wlb255, Hallman in-cockpit MBC
BUY MY FP RED 04 RS.... ONLY 16,000
pm me or call 540-222-8954
Offline
Sep 9, 2009, 04:24 PM
Quote:
boost gauge is hooked up after the mbc, but i get no pressure to the mbc either way
__________________
Offline
Sep 9, 2009, 04:28 PM
Personal Sales Rating: ( 7)
Drives: 06 gg mr
Does it read vaccum??????????
__________________
Quote:
Originally Posted by HobieKopek
Technicallly it's French.
It's "douche".
GARAGE / EBAY turbo kit 428whp,350wtq. .......My EVO has a drinking problem
442whp CBRD Mustang Dynp 376 wtq
NEW NUMBERS 480whp 370 wtq Thanks to BLOUCH TURBO and CBRD!!!!
Next setup is in the works .....stay tuned
11.6 @ 120 mph....... IN A 6 SPEED
Online
Sep 11, 2009, 07:09 AM
Drives: EVO8, CIVIC HB, 2500HD CHEVY
If the car was not boosting it would run like ****.
Offline
Sep 11, 2009, 06:40 PM
Quote:
what do you mean exactly? sorry im a noob, the car is boosting but im thinking its not boosting full pressure
__________________
Offline
Sep 11, 2009, 07:04 PM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
On the meter you will see it boost, or if it is the gauge pod from mitsu (or most other boost gauges) if the arrow points down, that will show the vacuum pressure in the intake lines. The whole point to see if it is registering the vacuum pressure is if it is just the pod, or a problem with the WGA.
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Sep 12, 2009, 11:31 AM
the boost gauge shows no pressure and doesn't move
__________________
Offline
Sep 12, 2009, 02:27 PM
It was a bad gauge, but we are boosting about 10psi right now
__________________
Offline
Tags
2006, boost, e46, evo, gauge, mbc, mr, pressure, showing, turbo, vacuum, vacuumpressure, works  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
