Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 2, 2009, 03:42 AM   #1
Personal Sales Rating: (0)
bloopsta26's Avatar
Drives: 05 sti...wanting an 03-05 evo
Send a message via AIM to bloopsta26 Send a message via MSN to bloopsta26 Send a message via Yahoo to bloopsta26
evo 9 boost issue
Hey,
so my buddy is having problems with his evo9. I have a sti so this is kinda diff for me but i need some advice on what to check or do. His car is having a bad boost issue. Its boosting like 25lbs or so. His mods are uicp,licp, intake, tbe. I check all his boost tubes and vaccum lines and they are all hooked up. i then checked his egr valve and they are all plugged in so then i went to his egr solenoid and one of the lines had broken off. would that be the reason why its boosting all sorts of funny? just wondering if thats the problem, which i know it has something to do with it but what else could it be if thats not it? thanks guys.....
__________________
35r sti
600rr
wanting an 06 evo
Offline
Old Sep 2, 2009, 04:15 AM   #2
Personal Sales Rating: (14)
vmrevo9's Avatar
Drives: 06 Evo RS
stock BCS or MBC? is he tuned? do a boost leak check.
__________________
Mods:
JunB.L - Espelir - Perrin HFC - K&N - Forge MBC - Walbro 255 FP - Advans
Prosport Amber/WhiteBoost gauge - GTWorx Springs - 17" Rota Boost - LICP
LC-1 o2 - ETS air filter kit - ACT HD clutch/Flywheel - SpoolinUp COP kit - Tuned by Mellon
12.541 @110.20 and 2nd place in show LOL
312 whp - 312wtq DLL
306 whp - 320wtq DynoDynamics AWD dyno
Offline
Old Sep 2, 2009, 05:33 AM   #3
Personal Sales Rating: (27)
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
If one of the nipples broke off one of the solenoids then yes that is a boost leak...
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Sep 3, 2009, 09:41 PM   #4
loud whitle....im assuming you have a spot where the pressure is def getting out. can you not check for boost leaks?
Offline
Old Sep 4, 2009, 10:22 AM   #5
Personal Sales Rating: (21)
05blue8's Avatar
Drives: 2005 VIII
Send a message via AIM to 05blue8 Send a message via MSN to 05blue8
You both need to do a boost leak test. That is likely the cause of ebramisag's issues. As for bloop's issues, why is 25 psi all sorts of funny? Sure it isn't stock, but he isn't stock. A 9 can handle the boost, and if he's been tuned he's fine. I'm guessing you are asking because you expect to see lower boost?
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Old Sep 6, 2009, 01:18 AM   #6
Personal Sales Rating: (2)
2003 Mitsubishi Lancer Evolution
EvoVIII808's Avatar
Drives: 03 Evo8
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
build a boost leak tester. its easy, and about $10-15 or less.
http://www.dsmtuners.com/forums/arti...et-tester.html
__________________
Quest for 700hp!! Buschur UICP,4" Intake, RNR GT35R, 3" Exhaust, HKS272/272, Skunk 2 Cam Gears, RC 1000cc inj, 255fp, AMS FPR, JMF Intake Manifold, SuperTech 1mm Valves, BC Valve Springs/Retainers, ETS FMIC, Full Race Head,
Comming soon.. ETS 3.5" Exhaust, Built 2.0
Offline
Old Sep 11, 2009, 01:41 AM   #7
bloopsta26's Avatar
ya the solenoid that has the 3 lines go to it had to be replaced. put a brand new one in there and nowits perfect...
but then took it to ams and had them put in a aem wideband/true boost and now everything is l messed up. killed a battery, now lights work, car dies.....and paided 4 hours of labor and the car had to be towed home....
__________________
35r sti
600rr
wanting an 06 evo
Offline
Old Sep 13, 2009, 12:26 AM   #8
EvoVIII808's Avatar
Drives: 03 Evo8
hmm thats weird.Check your fuse? maybe its grounded out to something.
__________________
Offline
Tags
boost, clicking, evo, issue, ix, lancer, leak, leakes, lines, location, lowering, problem, problems, rpm, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
