Sep 1, 2009, 09:40 PM
Personal Sales Rating: ( 6)
Drives: 2005 RR Evo 8
Stock Fuel System?
How terrible is the stock fuel rail and regulator???
im gettin tuned soon and am ordering injectors this week.. either 880's or 1000's ..
i was wondering if you guys would reccomend getting an adjustable FPR????
also how good is the stock fuel rail???
let me know
thanks
- mark -
__________________
AWD Revolution
www.AwdRevolution.com ( Site under Construction)
AWD Revolution Evo 8 :
(2008) 12.5 @ 110mph
(2009) 11.7 @ 120mph
Offline
Sep 10, 2009, 03:16 PM
Personal Sales Rating: ( 0)
2003 Mitsubishi Lancer Evolution
Drives: ford f350/ 2003 evo 8
I think if your going above 750cc's you should probably get a fuel pump and regulator because theres a good chance 880s + will be starved of fuel, but im running 750s on stock fuel system and im doing ok
Offline
Sep 12, 2009, 09:37 AM
Personal Sales Rating: ( 11)
Drives: 03'Evo8, 93' RX-7, 95' TSI, 92'TSI, 91'TSI x2, 92'GSX, 97'Civic EX, 08' GSX-R, 03' ZX6R 636, 03' Chevy Express van
Your stock regulator and rail will be fine with those injectors. If you decide to do one or the other, i'd do the rail. Good luck.
Aaron
Offline
Sep 12, 2009, 10:23 AM
Personal Sales Rating: ( 2)
Drives: Evo IX
fic 1250s here on stock rails/regulator. Fic bluemax is a really good injector
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Sep 16, 2009, 07:12 PM
Drives: 03 evo VIII
I have run 880s and 1250s on stock regulator/rail/lines. With a single walbro on 93 octane. No problems.
__________________
03 EVO
FatFab/35r/Shep/Magnus/QM/AMS/SparkTech/Cornfed on a FatFlash.
Best E.T. 11.300
Best trap 136.52
Offline
Sep 17, 2009, 06:29 PM
Personal Sales Rating: ( 4)
Drives: 97 GSX, 03 Cobra, 97 Supra 99 Suburban, 91 Blazer, 98 Bourget, and Harley Softail and more toys
No over run regulator problems like on the DSMs?
Offline
Sep 17, 2009, 06:38 PM
Drives: 2006 Evo IX RS
I have heard that once you start making over about 650whp the entire fuel
system needs to be upgraded including an aftermarket regulator as well.
Mainly because the fuel pressure will typically need to be higher than the stock 43.5psi
at WOT.
Offline
Sep 19, 2009, 10:07 PM
Quote:
at WOT.
That's so wrong. Yes the base fuel pressure should be at 43.5 but it rises about one psi for every one psi of boost. If it stayed at 43.5psi at WOT under full boost, we'd all have problems.
Aaron
Offline
Oct 4, 2009, 08:13 AM
Drives: 01' Evo VII
Good to know that I can just throw a Walbro in and keep the rest of the system.
__________________
01' Lancer Evolution VII
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
