Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 13, 2009, 09:06 PM   #1
Personal Sales Rating: (0)
Evogargoyle's Avatar
Drives: '92 Lancer Evolution 1 GSR
Check Engine/ Weird boost/ Low idle
I've gone through the forums to see if this has happened to anyone else!!
My Evo 1 just recently started acting weird, For starters once the car gets up to full running temp I have a loss of power, my RPM gauge drops off to 2200, boost spikes to 10 psi and holds steady, and A/F dropps off the charts!! The first time it happened I checked all the electronics and found a completly Blown coil pack! With that replaced I went for a test drive and it happened again!!! This time I checked everything that I could pull out, all vac lines, checked the turbo, I/C hoses, throttle body, spark plugs and all fuses!! It's idle its really rough and sounds like a Subaru Boxer engine!! I Cannot figure it out! PLEASE HELP
For background I've got aftermarked headders, intake filter, iridium plugs, Moroso wires, and I'm not sure for internals!! Boost is at 21psi!!
I hope that someone can help
__________________
"When You Turn Your Car On Does It Return The Favor?"
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
