Aug 11, 2009, 11:26 PM
Personal Sales Rating: ( 6)
Drives: 2005 RR Evo 8
Weird Boost Leak
So recently i replaced some things and decided to boost leak test the car again.. soo i tested it using the inlet of the turbo like i always do.. and tested it to 20psi, it was fine.. soo i decided to go to 30. it was going fine than all of a suddon a weird releasing noise came and than it would not hold even 1 psi. soo i thaught i popped a coupler... nope all of them were fine...
soo i tried listenin for the noise.. it was too extreme to pinpoint it soo i decided to test bypassing the turbo.. hooked the tester to one side of the intercooler and it still wouldnt hold... sounds like the boost is going into the motor and not holding..
soo i figured throttle body seals again.. soo i ordered the works ones and replaced them... than boost leak tested it again and it still wont hold.. this time i went thru the turbo and did not bypass it.. the air sounds like its coming from the turbo but u cannot feel anything.. it also sounds like it is going thru the motor and not holding at all
anyone have any idea????
also i am throwing a P1071 system to lean code
let me know what u think the issue is..
my new turbo goes on next weekend and i want this taken care of
thanks
- mark -
__________________
AWD Revolution
www.AwdRevolution.com ( Site under Construction)
AWD Revolution Evo 8 :
(2008) 12.5 @ 110mph
(2009) 11.7 @ 120mph
Online
Aug 12, 2009, 12:15 AM
Personal Sales Rating: ( 8)
Drives: EVO\\\, 4g64 Mighty max, Gmc Acadia, Yota Tundra
If you remove oil cap, can you hear air inside, when pressurized?..
__________________
380whp/340wtq Mustang dyno
Stock 8 turbo @25psi
E85 clean air vehicle (:
GST Motorsports tune
Offline
Aug 12, 2009, 05:52 AM
i will have to try that... i know i can hear a sound like the air is going into the motor.... like it will not hold any psi of boost on the boost leak test
__________________
AWD Revolution
Online
Aug 12, 2009, 09:13 AM
Personal Sales Rating: ( 0)
Drives: 03 evo 8 bby
u do know if ur gonna boost leak test the piping....ur supposed to cap off the intercooler piping at the throttle body that way u dont pressurize the motor...and ull find a lot of leaks which will help with driveability i know the shop that tuned my car n built my motor i have upgraded couplers and tbolt clamps and they still found 5 boost leaks throughout my piping....good luck
__________________
espelir catback dc sports cat delete downpipe titek 3" 02 housing hks 272 cams xs engin fmic and piping 880 injectors 255 pump dejon tool greddy type rs bov tein lowering springs built 2.0 block je pistons eagle rods acl race bearings arp main head rod studs brian crower valvesprings and retainers stock valves fp red turbo balance shaft eliminator kit aem wideband gauge milspec exhaust manifold high pressure throttle body seals aem intake optima battery relocated to trunk
Offline
Aug 12, 2009, 03:24 PM
yeah u only cap off the throttle body if ur looking to see if ur piping is leaking.. not if ur listening for throttle body, intake mani leaks.. everyone just does it thru the intake of the turbo.. the best way is to do it from ur lower ic pipe....
im gonna say yes to hearing air coming out the oil cap.. honestly now that i did the throttle body seals i dont hear any air at all coming from the intake mani just from the turbo area but it sounds internal
what could this be??
__________________
AWD Revolution
Online
Aug 12, 2009, 11:56 PM
so i ran the tester again and came up with check engine code for egr valve insufficiant...
soo i felt around the intake mani and the valve and came to find out the vaccum line on top the egr valve musta blew off during my boost leak test...
soo i fixed that, reset my ecu and drove 50 miles.. runs alot better and no check engine light yet ( crosses fingers)
i bet when i was testing it all the air was pouring out of this vaccum
soo good i found this
now its time for new turbo install next weekend
__________________
AWD Revolution
Online
Aug 13, 2009, 02:36 AM
Personal Sales Rating: ( 27)
2005 Mitsubishi Lancer Evolution
Drives: '05 Tarmac Black SSL VIII
That is what I was about to tell you to check!
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Aug 13, 2009, 04:11 AM
Drives: Mitsubhsi EVO 9 & Nissan 240SX
nice glad you got everything fix, what turbo do you plan on running?
Offline
Aug 13, 2009, 05:27 PM
just a little baby Gt30R .... the head just went back on with L19 studs, Hks 272/272 cams, oem mitsu headgasket ... soo hopefully with this turbo crankin 32psi the car should move a little
__________________
AWD Revolution
Online
Tags
boost, cap, evo, feel, finding, flash, galant, leak, mustang, runs, sound, test, tester, vr4, weird  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
