Jul 26, 2009, 10:11 PM
Personal Sales Rating: ( 0)
kelford install
just installed kelford 272s in my ix mr... took a lil while but runs alright now... at an idle it car feels like its gonna die out... havent tuned it yet but how can i raise the idle so it doesnt want to die out... and oil like flickers...
Offline
Jul 26, 2009, 10:40 PM
Drives: 03 evo viii in blue
tunning software can raise the idle
Offline
Jul 26, 2009, 10:44 PM
Drives: 2003 Evoluion VIII
kelfords are known to do that so, tunning will be needed asap so you can have the right idle...
Offline
Aug 2, 2009, 11:34 PM
Personal Sales Rating: ( 6)
tuneeee tuneee tuneee
__________________
HKS + PROSPORT+ APEXI +HALLMAN + 4WS TUNED= 350 WHP....so far
Offline
Aug 2, 2009, 11:35 PM
Personal Sales Rating: ( 1)
Drives: Americas first batch of evos
you NEED to tune the car for these guys to work, i also have kelford 272's an id didnt idle for **** until i got the car tuned
__________________
366whp 342lbs @ 24psi Sean Ivey Tune Stock turbo, pump gas and no porting of anything.
Offline
Aug 2, 2009, 11:54 PM
Personal Sales Rating: ( 10)
2003 Mitsubishi Lancer Evolution
Drives: 03 Banana EVO VIII
all answers point to: get a tune. A tuner definitely can raise the idle thru software. Do not fiddle with the throttle body that is calibrated for a reason.
__________________
You have never lived life, until you have choked someone out!
PS3 ID: Kinikuchunks, Add ME for some Street fighter 4 and Killzone 2 action!
KUNiiiZZZEEE Dial-IN
Offline
Aug 5, 2009, 07:55 AM
Personal Sales Rating: ( 2)
Drives: volvo 740 turbo
I ran through and re-scaled the maf around idle, and mine idles really nice with the a/c on, and still has a bit of the bumpity bump with the a/c off. Took about 10 minutes to run through and do that.
__________________
03 TB EvoVIII, ams 35r, fmic, cams, etc. 440whp
90 Volvo 740 16v, t67, blah blah blah 512whp
Offline
Sep 9, 2009, 12:23 PM
its getting tuned today with snow performance kit and fp red...
Offline
Sep 9, 2009, 12:49 PM
Quote:
good dont wanna be riding around with an untuned car and cams
Offline
Sep 14, 2009, 11:57 PM
Quote:
yea i hear ya i rele didnt drive it that much before the tune.. and when i did i babied it... car made 445 with fp red, snow kit, cams and all other bolt ons... stock block and 50/50 water meth mix
Offline
Sep 15, 2009, 02:25 AM
How do you like that snow kit?
Offline
Sep 15, 2009, 09:17 PM
Quote:
its not bad...idk if im gonna keep it cause im rele lazy and im gonna hate having to fill it every so ofter, might sell it to buy engine internals... so im testing waters
Offline
Sep 15, 2009, 09:27 PM
Drives: 2006 Evo IX RS
So which method did you use to swap out the springs and retainers.
Head removal, air compressor in plug holes or the manual crankshaft
turning with rachet?
Offline
Sep 15, 2009, 09:44 PM
i used the air compressor in plug holes to keep cylinder aired up so the valves didnt drop...
Offline
Oct 10, 2009, 10:15 PM
Personal Sales Rating: ( 9)
i've been searching for a while on the Spring Retainer Seat install. In the How to thread, several guys in the discussion section had the pistons move when applying pressure.
One guy tried leaving it in gear wit the emergency brake on etc.. and still had it move, screwing up his timing.
Is there a sure fire way to use the air compressor method without the the piaton(s) slipping timing?
I'm getting ready to do this with a Kelford cam install and would sure like to know.
Not interested in theories, just experience & proven results. Thanks!
__________________
"happiness is a warm 4g63"
"my dyno is a quarter-mile long"
And my absolute FAVORITE!
"please shorten your signature there is no need for it to be 20+ lines long
thanks,
evom staff "
FINE...
03 VIII FP Red(80mm inlet & Oil Line)RMR3"TB&DPInvidia O2BuschurP&CStockExManiBuschurTwinPumpRC1200ccAeromotiveFuelRailNiseiICInjenIC&Intake
MilSpecTB&PIForgeBOVHallmanBCw/remote272KelfordsFPBeehiveSpringsExedyTwinTXSTuner Pro&WidebandE-85TobzTuned
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
